Fridge help (1 Viewer)
Apr 25, 2021
6
autocruise rythm
I have a domestic rms 8401 fridge when you switch it on it goes straight to 12 volt and alarm sounds, you cannot switch to 240v or gas as non of the buttons do anything,I’ve tried unplugging fridge a5 the back etc but nothing seems to work, any help please.
Dec 6, 2011
11,636
25,579
South Wales
Coach built Adria
hi welcome,
was it working normally for you before you noticed the fault?
has it got a button you hold in for 5 seconds and it resets the fridge?
P
Apr 25, 2021
6
autocruise rythm
Hi Phill
last time I used it all was working well, but switched it on yesterday and it was straight onto 12 volt and two bars of temperature and the alarm was flash and beeping, tried the reset button but it does nothing
11,636
25,579
South Wales
Coach built Adria
i am sorry i dont know that fridge model, but does the alarm go off if you start the engine?
is it plugged into EHU ? if so does it stop beeping if you disconnect the ehu?
Upvote 1
P
Apr 25, 2021
6
autocruise rythm
No I don’t think so it beeps for about 20 seconds when you switch it on then the reset button flashes and you can’t reset it
11,636
25,579
South Wales
Coach built Adria
I would disconnect EHU and switch gas off and run the engine and then see if the alarm stops and the fridge runs normal.
maybe battery is low...
its difficult trying to help over tinternet ;)
process of illumination is all i can think of.
deleted79651
2,279
6,140
Our new to us m/home has the same problem and it's been the bain of my life since it was delivered on Wednesday. The 12v failure started as an intermittent problem, but had gone permanent by the time we received the van. Dealers have supplied a new Control Panel, and I hope to get it fitted tomorrow! Then I can start to enjoy Brunhilde instead of cursing her! Gas and Mains leccy operation are perfect, just the blessed 12v that won't turn off, irrespective of how long you hold the 'Off' button in. The latter now has a double barreled name; it's 'Puck Off Button...' [in polite company, because it's also a little Tinker[bell]] :Grin:
Steve & Elaine
lunarman
2,158
2,455
South Glos
since 1994
Page 28 of the user manual gives the diagnosis of fault conditions the one you describe looks like it is indicating low or no 12v. Have you got the optional on board battery back up ? the 8 AA batteries may need changing.
11,636
25,579
South Wales
Coach built Adria
you will need to subscribe to post more than 5 posts, so you may be stuck unless you join.
hope you can get it sorted especially if you have tried all that has been suggested.
but it still sounds to me as if there is a low voltage supply.
