Benimar benivan 122 2019,when filling the tank it goes up to 100% but then without using any water it goes down to 75,then 50 and reading stays at that level but l always get overflow wasting water.
That's because the tank probes are rubbish, doesn't matter make of van.Benimar benivan 122 2019,when filling the tank it goes up to 100% but then without using any water it goes down to 75,then 50 and reading stays at that level but l always get overflow wasting water.
Agreed; I'm finding the same as I get more use out of our Corninium Duo. I now fill it until water comes out of the overflow which is a bit wasteful but I'm learning to see the signs so I won't be wasting too much in the future.That's because the tank probes are rubbish, doesn't matter make of van.
On my next conversion I'll be putting a high level and low level float switch in wired to a buzzer, it should solve the problem.I recalibrated our water level meter to read accurately at lower water levels so we don't run out, and fitted a float switch connected to a buzzer to let me know when I'm filling that it's full.
It's not sophisticated, one of these at 25% full, another at, let's say 90% full to give time to turn the tap off.I wish I was that clever
I'm with Vipar on that one - 13 core cableEasy to fit with 13 core cable
What about using one of the blue tooth gas cylinder level monitors?
You are a rebel...For me it's never been an issue.
If it sez full I've got loads, so no worries.
If it sez empty Id better get some soon, so no worries.
I'm past fretting about a water guage not being accurate.
I’m with you Vipar! I can barely (and only allowed) to change a lightbulb…!Believe me it is sophisticated, it has wires coming out of it.
