Fitting Usb Socket To 12v Feed In Van (2 Viewers)
Apr 14, 2015
15
8
Prone
I want to be able to charge my iPhone or iPad when I am wild camping or not on a site with electrical hook up. The cigarette lighter type sockets in the van dashboard will do the job while we are on the move but not when the ignition is switched off.
I currently have a 12v socket in the van, with a remote switch, , which holds a twin pin plug, which was designed to power a TV and I want to convert that to a double USB socket. I appreciate i could just wire a twin cigarette lighter type socket into it but it's not very elegant. Does anyone know of a reasonable looking twin USB socket which I could use for this purpose? There seem to be plenty of 240v sockets round with USB sockets built in but nothing for a 12v feed.
43,344
49,545
First one i came to on ebay
If you look amongst the listings you can get the same with a square or rectagular bezel which look quite smart.
Search 12v usb socket
D
Deleted member 29692
Have a look on eBay. Loads to choose from
EDIT: Too slow again
43,344
49,545
18,038
48,155
I fitted one last year and it has been a great success, I may fit another three, one for each corner! Go for USB 2.0 or above if you can, as they provide more current.
43,344
49,545
I fitted the one in my pic, above, to my car.....saves having those awful plug-in things hanging out the fag lighter which is part of the ashtray and normally closed.
One of the best mods i have done.
bhs
214
137
Louth
b class
since 2006
Did wonder if the cheap versions actually supply 5v to the USB when engine is running and feeding battery upwards of 13.8v In my feeble attempts to check I saw off a few fuses and am none the wiser?
18,038
48,155
The linked to by @NickNic has an input voltage range of 12 to 24 volts. I haven't looked at the other one. So I guess you just need to check when buying one it has this sort of range.
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
How about this for a solution? I have replaced several sockets in the house with these:-
No more chargers, still have the mains sockets and USB outlet as well. I think they will become very popular given time.
Wyn
WynandJean
6,670
3,303
West Midlands
Doh! Just re-read the OP and realised it was for wild camping and actually says withou EHU. Never mind, it still applies.
Wyn
Wyn
Nov 30, 2009
6,548
149,069
Pickering
PVC the PUG
Ralph's gone overkill with the blooming things in the PVC.
One each side in U shape lounge overhead cupboards ( charging while traveling so things don't slide about) .
One each side under overhead cupboards To use whilst lounging.
One in kitchen area.
One in cab. So six In total !
There's only two of us now not five. ::bigsmile:
He does like his gadgets though.
D
I can't honestly say I've had a voltmeter anywhere near it. What I can confirm though is that when the engine is running there's a nice blue light on the USB socket and it charges my phone which is what it's there for (y)
D
I fitted one of these, my battery is normally very good, didn't use the MH for about 3/4 weeks, flat battery. IT seems they use power all the time. I am just now fitting an on/off switch. I guess They are fine if you use the camper often......or it's just mine. :)
They do - the little blue neon. Mine's connected to an ignition live not a permanent live so it's isolated when the engine is off.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
Get the right one. The ones on ebay vary considerably with their output. They all give 5volt but output varies from .5 amps to 2.3 amps. Basically a four fold difference in charging time. Or perhaps more importantly something like a tablet used for navigation could be discharging faster than charging if you choose an output too small.
After finding the ones that I originally fitted were 1.2 amps and could't keep up with the tablet screen I changed them for 2amps ones fine now. As far as I know the higher amperages will not harm anything
Dick
Reactions: DBK
Kool Kroozer
1,361
2,228
Cannock Staffordshire
Low Profile Hobby Premium
Always learning
I did similar in our PVC, fitted about 5 USBs and an extra 4 240v, maybe a little overkill but its always handy to have power at all ends of the van i think, am just doing the sam now with our Hobby - only problem is they take a couple of wweks to arrive from China, just cant understand why british sellers want so much for the same thing - less than a few pounds with free postage from china - have seen the same thing from UK sellers for as much as £17 each, would rather wait 2 weeks, especially when buying about 7 items :LOL::LOL:
