Fitting a 12v battery display advice (1 Viewer)
Ironside
205
501
Warwick
Burstner Solano 695G
Since 2016
Hi peeps,
I have purchased and fitted a 12v display and it works fine then as an after thought wondered if it should have an inline fuse? And or switch
It’s wired direct to my 2 leisure batteries 115AH x2
Any advice appreciated thank you
Badknee
7,478
432,461
notloB
Vantage Neo
Living the dream.
Yes and no, a 1 amp inline fuse wouldn’t go amiss and no to a switch as it saves leaving a night light on for when you get up the numerous times in the night for a pee. :LOL:
43,793
53,077
Wouldn't worry about it draining your batteries.
It probably draws 10 to 20 milliamps/hour so will run for 500 to 1000 hours before you're down to 50%.
But as said, a 1 amp fuse in case it decides to go pop and short circuits.
Apr 27, 2016
7,403
8,829
Manchester
A class Hymer
Since the 80s
The Electroblock in Hymer MHs have an internal voltmeter and a thin separate dedicated wire to the battery. It has a 2 amp fuse to protect the wire, which is a good idea for any voltmeter.
Ironside
Ironside
205
501
Warwick
Since 2016
Fuse fitted many thanks fellow funsters
Need sunglasses on in the van as the led’s are so bright from the volt meter
TheBig1
Nov 27, 2011
17,851
44,361
I am pleased to hear you added the fuse, those little voltmeters are cheap chinese rubbish and can fail dead short. personally I would fit a momentary switch so it only powers up when needed
RogerThat
1,131
1,079
North West
Auto-Sleeper PVC
Since 2014
I'd do exactly the same (y)
It's not something you need to monitor all the time :)
