Dazz
Hi all I’ve just purchased a fiat Ducato swift 622 .But the front captain seats don’t swivel.So I’m looking for help on how to turn them into swivel seats info on what to buy and advice idd be grateful
but you can change the seat base to a lower one to take account of the height of the swivelBe aware they will make you sitting position higher - so if you’re tall beware
I am pretty certain that the same swivel fits the x250 and newer x290, so should fit your 2019 ducatoI hope it’s that easy lol now need to find the right plates for 2019 fiat Ducato
Surprised there isn’t a modification to raise it somehow.And the hand brake ever will be lower
indeed there is, but 3rd party adaptions, rare spares do one and kobran anotherSurprised there isn’t a modification to raise it somehow.
Hi look on ebay or try Jenkins seats .co.ukHi all I’ve just purchased a fiat Ducato swift 622 .But the front captain seats don’t swivel.So I’m looking for help on how to turn them into swivel seats info on what to buy and advice idd be grateful
That should have said jennings seats .co.ukHi look on ebay or try Jenkins seats .co.uk
Valid point! I have unusually long arms (I can scratch my feet without bending). The handbrake goes down a veeery long way & I can just about work it.And the hand brake ever will be lower
Fitting the swivel is pretty straight forward for basic diy skills. undo 4 bolts and remove seat
Not if you have batteries & / or an Elektroblock or similar under the seats.but you can change the seat base to a lower one to take account of the height of the swivel
I removed the swivel because I found the seat uncomfortably high on long drives. I hope this isn’t a stupid question (it probably is!) but is it possible to lower the existing seat box/base or do you need to replace the seat box/base with a lower one?My advice is to seriously consider a lowered seat box - it makes all the difference to a pleasant drive... with my first van I always felt I was driving scrunched up to see below the sun visor... in my current van with lowered seat boxes, the driving position is exactly where the van maker intended it to be.
But of course, you may have to consider what's under the seat, such as batteries.I removed the swivel because I found the seat uncomfortably high on long drives. I hope this isn’t a stupid question (it probably is!) but is it possible to lower the existing seat box/base or do you need to replace the seat box/base with a lower one?
Thank you for your time to respond to me but my husband has just informed me they are Hyundai Trajet seats he has put into the Fiat (my mistake). Your suggestion above isn't possible as the bolts are different sizes. Any other advice for me. ? Most grateful. Thank youunbolt the catch from the original seats and fit those to the alhambra seats. Fiat and the vw group use different size seatbelt catches
Use the bolts for the ones you want through the seat belt sockets you require. If hole is too small drill them bigger. Photo's might help as wellThank you for your time to respond to me but my husband has just informed me they are Hyundai Trajet seats he has put into the Fiat (my mistake). Your suggestion above isn't possible as the bolts are different sizes. Any other advice for me. ? Most grateful. Thank you
