Mad dog
What about one inside your gas locker....maybe it could be routed outside too?Hi, I see the BBQ points that you can fit in the bodywork (by cutting a hole), but can you get a quick release type one that you can mount just under the edge of chassis/body?
Not sure about the quick release type but the firm that fitted the bbq point on my van (autogas 2000, did a very good job) wouldn't place it in the actual bodywork itself as it would have compromised the habitation area. They fitted it so it accessed the gas bottle compartment which was fine. Don't know if this is a legal requirement just in case you are looking to fit it yourself.
I will but it'll be later today if thats OKThanks, any chance of a picture please?
Two on Tour fitted one and a refilling point to his gas locker door a few years ago......Thanks, any chance of a picture please?
Thanks, but my gas locker is just behind the rear doors (PVC), so I can't do that.Two on Tour fitted one and a refilling point to his gas locker door a few years ago......
here....
Anyone fitted an external gas point
such as a bullfinch http://bullfinch-gas.co.uk/outdoor-utility-points/gas-point-131-detail / or truma one? if so, where / how? Ta :)www.motorhomefun.co.uk
Thank you, that might be an option but it's not ideally where I want my bbq.As you have a PVC, how about mounting the BBQ point on one of your rear quarter bumpers ?
I know a few Funsters have mounted their refillable gas points in this position.
https://www.motorhomefun.co.uk/forum/threads/gas-filler-location-on-ducato-pvc.186514/#post-3074662
That's what I'm after, just something simple Do you know what the connector is &/or where I can get it from? I can make the bracket holder if necessary. Cheersmy self buiuld had one on a bracket under the sill i will look for a picture
click on my building renee link in my sig below its the first picture on the b log
Thanks, I was thinking of teeing into the 8mm pipe after the regulator on the low pressure side. Do you know if these fit the Cadac quick connect pipes?You could put a bbq point or tee and tap then flexible hose to quick release extention through a gas dropout hole
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=111474012986
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=133422891527
Ps example only this is expensive
i think it came from ebay it was a faff to fit as the thread didnt go through the firsdt breacket i made if i was doing it a gain i would use a gas valve and fulham nozzleThat's what I'm after, just something simple Do you know what the connector is &/or where I can get it from? I can make the bracket holder if necessary. Cheers
