Error e513H
nef1k
Hymer mlt580
I have a error e513H. what should I do.
hi welcome, need a lot more info,
Something to do with a Truma Combi Boiler. :gum:
Is it Truma, if its e and h usually signifys heating and electric.
have you unplugged the leccy without shutting down the heating ? or is the heating main switch on ?
are you sure its 513 ?
Cant find that code in the Truma lists🤔are you certain it’s 513 ?
:welco:
If its a Truma there are loads of codes up plebs aren't allowed to know about, best to ring them.
The combi boiler control is a mysterious box of tricks I think you may have switched off the power without shutting down the heating controls ,you will need to reset the system ,you will find a list of fault codes in the manual and also on one at the Truma site.
I think it’s not shutting down the system before unhooking. Long press the button to turn the Truma off, turn on your main van control panel, then turn the Truma back on. Hope it helps!
AND wait 15 mins
From FB
Jo Huggon
Know the problem!
It's not the heating coming on.
If you are heating the water on high with electric, eventually the boiler gets too hot in a confined space, it turns on the heating fan to try and cool down and blows the hot air into the van. Even if you switch the water off the boiler will still try to cool down by running the fan. It's a design fault. Water on it's own just seems to get too hot.
PS error code is:
Water temperature switch opened during operation due to overheating.
Это Трума, если ее e и h обычно означают отопление и электричество.
вы отключили leccy от сети, не выключив нагрев? или главный выключатель отопления включен?
ты уверен, что это 513?
Yes
From FB
Jo Huggon
Know the problem!
PS error code is:
I have a problem in another, the boiler does not heat up. cold tap water flows from the hot and gives an error e 513H.
What happens when you reset your boiler after 15 mins? Like this.
Is the blue button pressed in on the boiler?
Looks like you need to subscribe now, you’ve ran out of free posts. Only £15 for the year, I’m sure you’ll get your money’s worth :-)
