Entry into Nissan Navara with a Flat Battery (2 Viewers)
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Hi a fellow 5ver with a manual 2006 Nav. woke up yesterday with a totally dead battery - consequences were that the central locking would not work so no access to cab or bonnet . After much thought it was decided to drill out 3 honeycombed plastic panels in the grille---known by observing a sister Nav. .Then 12mm socket onto the 3 bonnet release bolts and hey presto access available Moral of the tale if battery f.....d there is a way in without expensive call outs Alan
scotjimland
2,327
10,087
A Woosh bang
Alan
Good thinking ,
probably a silly question.. but why would the key not open the cab door manually ?
jim
zaskar
1,159
371
UK
5th Wheel
Good thinking ,
jim
There is no key mate. Nissan keyless entry! great when it works.............:Doh:
scotjimland
2,327
10,087
A Woosh bang
Imagine that.. no keys.. what is happening to the world.. :Sad:
I knew there was a sensible answer, cheers ... :roflmto:
jim
bashers
108
Bedfordshire
RV
3! Been boating for years. Now just bought an RV
OH YES THERE IS
under a plastic cap on the passenger handle.
classc RTFTM!
:ROFLMAO:
zaskar
1,159
371
UK
5th Wheel
OH YES THERE IS
classc RTFTM!
:ROFLMAO:
Ehhhhhh?:Confused:
edit= Nice one Bashers! :) Just checked my 08 D40 and you're spot on. Remove the plastic cap off the passenger door handle and sure enough, there's a hiddden key slot.
Good tip that,you taught me summat usefull there. Cheers. :)
Forestboy
5,023
8,338
Forest of Dean
A Class Hymer B694 tag
This has happened to my Pathfinder when I've returned from the states.
There is a key folded into the remote and a keyhole in the passenger door under a small plastic cap.:thumb:
chatter
3,689
937
cheshire
5th wheel
Im betting someone is kicking themselves and wished they had asked first now. Thats what is great about forums someone out there always has the answer.
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
And I've got to say that one was about as good as it gets.::bigsmile:
robrobc
243
Cotswolds
None Now
Better actually, but let's just remember that it was this kind of dogged determination in the face of adversity coupled with a reluctance to think outside the box that made Britain "Great" ::bigsmile:::bigsmile:::bigsmile:
Heyupluv
3,862
1,593
France,
touring many years..42+
Am I missing something .........telling everybody where the spare keys are.. would it not have been better PM........
there many people read these threads even though they are not motorhomers.
I hope none of them are in looking at M/F tea-leafs I mean............car T---ths
but I must say a good thread
Mel
zaskar
1,159
371
UK
5th Wheel
Mel
Where does it say that?
Heyupluv
3,862
1,593
France,
OH YES THERE IS
zaskar
1,159
371
UK
5th Wheel
OH YES THERE IS
Ahhhh.:Smile: What it says,(EDIT = or should that be, what it means) is that if you remove the plastic cap, you will find the SLOT for the key for emergency entry, NOT the key itself.:thumb:
scotjimland
2,327
10,087
A Woosh bang
OH YES THERE IS
well, I'm sure that the tea leafs out there are better clued up than the OP about a hidden lock... it's all in the owners manual in a downloadable pdf ... hardly a state secret.. :RollEyes:
at least I don't feel so silly for asking in the first place.. :roflmto:
43,329
49,446
OH YES THERE IS
classc RTFTM!
:ROFLMAO:
who thought that one up !!!!!
you're outside with a flat battery, the keys on the inside with no access to it !!!!!!!!!!!!!!. :Doh::Doh::ROFLMAO:
had this problem with stepdaughters micra.
flat battery, lights left on, pop out number plate lamp, touch a wire to bulb holder pos teminal, another to earth and connect both to a 'donor' car/booster pack and it will backfeed the power and the fob will work.
may not work if lights are off though.:Doh:
ps...did check the plastic OUTSIDE cap and guess what......nothing, nadda, nowt, just a hole where the lock was meant to be.
miss understood this first bit thinking there was a key under a cap on the INSIDE handle...
zaskar
1,159
371
UK
5th Wheel
NOOOOOOOOOOOOOOO!!!!!!!!!:ROFLMAO:
The KEY isn't there, the SLOT for the key is there, that's all.
It's just a means of being able to get in the car if the battery goes flat. You still need the key and, as the owner, you're gonna have that in you pocket aren't you?
It's more of an asthetic thing I suppose. Nissan have removed the VISIBLE key slots from the outer handle, but they've still gotta provide a means of getting in if the battery goes flat and the "keyless entry" wont work, so they've hidden a key slot behind the trim on the pax door OUTER handle.
Clear?:ROFLMAO:
43,329
49,446
never had anything with a keycard but i do remember being in something that had and you had to put the card in a slot in the dash before you could start it.
no idea what it was though !
Heyupluv
3,862
1,593
France,
Sorry I did not realise......I thought a spare key was underneath…… my apologies
Mel
GIBLA53
GIBLA53
267
25
Powys/Spain
Adria Coral Compact
since 2002
Great stuff guys and gals this is such a brill. forum - i now haven't the heart to tell my mate that he didn't need to drill . I looked and found the key insert on passenger side but tried my ignition key -this didn't fit then looked inside the key-fob no sign of any other key can anyone advise? Alan
