Wissel
Being fulltime, I'd really like to be solar sufficient for as much of the year as possible. I have battery capacity for 3-4 days (use 100-130Ah per day) and will have 750w of solar panels.
I keep trying to come up with a way of angling my panels that is simple, but will get used. I think if I had to climb on top of the van to angle the panels, I'd hardly bother.
So I'm wondering about using waterproof linear actuators. The trouble is, even an idiot like me can see the actuators would need to be at an angle when the roof is down. I have no idea how steep that angle needs to be?
I know there are a few on here with engineering backgrounds. Hoping one of you can help here.
This is what I'd like to do:
The frame to hold the panels would be 1500mm wide and 3m long. I'd fit an actuator at each end, the ones drawn are 600mm closed and 1050mm extended. The frame would be 60mm aluminium box (I hope), so 120mm total height. I want this height as it means the top of the panels clear the top of my awning, so no shading.
This allows the actuators to be fitted at 10 degrees. Is this likely to be sufficient?
Any ideas appreciated.
I keep trying to figure this out, deciding it's too difficult and giving up. But if it is possible, and not too heavy, I'd like to fit something similar.
