Engine Management Light (1 Viewer)
Feb 18, 2016
91
52
Kings Lynn
Autotrail Mohican
Since 2013
Hi all,
Have a question about my engine management light comes on in 4th gear at 2500 revs and lose a bit of power. Some times in 2nd gear too.
Any ideas what it may be?
Have found a Fiat dealer near Benicalo, so will have to book it in I think.
TIA
Barry
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Mine was the DPF - diesel particulates filter in the exhaust system.
I hope not because they cost a fortune (£800+) especially abroad. If it is that, hope you can get it back to the UK.
Floridalil
Feb 18, 2016
91
52
Kings Lynn
Autotrail Mohican
Since 2013
Thanks all, will find out soon after the dealer takes a look.
Hope its not the DPF
Have milage of 33k, not too high.
Can drive it ok, just nurse it a bit.Started after we got to France on way to Spain,so drove on.
Cruises along ok.
Barry
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
If you drive it for a bit in a lower gear you may find that the higher exhaust temperature will burn off any crap in there and return it to normal
Peter
tonka
10,830
21,528
Cannock, Staffs
A class Burstner 800
Since 2000
Invest in a OBD2 reader (£10 ebay) and an app for phone / tablet..
At least It will show the problem codes. I had a similar thing and it was the DPF Sensor.. There are a few threads about those type of issues on here.. Read some really horror stories where dealers change the most expensive parts.. Mine cost £130 for part, fitting and re-generation.
A can of DPF / Fuel cleaner is worth a shot and as above, give it a blast at high revs the get things nice and hot..
http://rover.ebay.com/rover/1/1185-...2&toolid=10001&campid=&icep_item=222550993140
23,782
133,652
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Cruises along ok.
Barry
If you have cruise control it can even be the brake light switch incorrectly adjusted/loose.
tonka
10,830
21,528
Cannock, Staffs
Since 2000
Can you expand on this...
Not sure if it could be related to a issue I have when using Cruise and hitting a hill.
bobandjanie
8,161
15,796
Javea, Spain
Pilote V600g
Ours was the dpf filter at 10000 miles it was done under warranty , it was probably the previous owner being a bit steady, its now done 53000 and no problem wants a good run at high revs and that might clear it out. :LOL:
You can get a cleaner that you put in the tank. (y) Bob.
