Electronic Overheating Alert (1 Viewer)
NickyandAndy
5
Suffolk
Burstner Delphin T680
4years
When travelling with the Dometic fridge on 12v we are getting a beep and then the following message on our display 'STOP! Electronic Overheating'. (Picture attached) We turn the display off and then on again after about half an hour and it is fine for a while after. Can anyone give us any idea what might be causing this and what we can do?
On a mother note we need a new door handle/mechanism for the external door into the living area, does anyone know where can get this from?
Thank you
Nicky
  • Motorhome.pdf
Dec 12, 2010
5,411
21,562
Cumbria
since 2011
@NickyandAndy You'll have a Reich ebox fitted I imagine ? Basically what happens is that the circuit board isn't man enough to supply the current the fridge needs (poor design). This results in the circuit board overheating and a new unit from Reich is around £750, or a repair and upgrade by Apuljak Engineering is around £400. Ask me how I know ?:(
On longer drives, I usually run the fridge on gas (now wait for the haters)
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
I drive everywhere with my fridge on gas... (and often on 12 volts at the same time.)
Always have... always will.
(And I drive bare footed with my grey water drain tap open.)
JJ :cool:
NickyandAndy
NickyandAndy
5
Suffolk
4years
JJ :cool:
Thank you for the replies, yes we have the ebox fitted. What are the possible safety implications of driving with the fridge on gas? And how do you have it on gas and 12volts at the same time? Sorry very green with these issues!
Nicky
NickyandAndy
NickyandAndy
5
Suffolk
4years
Can't even work outlaw to reply properly!
Nicky
TerryL
6,184
8,186
North East
Low Profile
Think he was being a bit, well, cynical....
To legally drive with gas switched on you need a special regulator which has a "G" sensor and switches the gas off if it detects an accident. Called Secumotion I think.
You've almost used up your free posts so if you need any more info you'll need to subscribe. It's only £15 and will be the best deal you ever have motorhoming. Gives you full access to all the info and resources plus discounts, social events and even a bit of Fun too!
Feb 22, 2008
12,265
45,050
Norfolk
Nearly Tugging
Since 2004
US RV fridges , or the ones I had don’t have a 12v option , just mains or gas.
JJ
Mágica
May 1, 2008
19,259
48,046
over 50 years
I most certainly was NOT being cynical... see below.
I have a 1987 Hymer 660S.
These motorhomes were built to last and contained equipment totally devoid of the computer controlled gizmos of today.
It has a three way fridge... the operator decides which power source to use. You can have it on gas AND electric (240 volt or 12 volt) if you want.
These days, in modern vans, the fridges often have automatic power selection... I read post after post after post where the selector system is having a wobbly and the fridge won't work.
Not with my fridge. I make the decisions... not a circuit board.
JJ :cool:
scotjimland
2,324
10,062
A Woosh bang
not such regulation.. only advice ..
drove for years with an RV with no crash sensor regulator.. AND the fridge was on gas while we drove.. as mentioned earlier many RV Fridges don't have a 12v option.
TerryL
6,184
8,186
North East
Low Profile
My apologies - seems I am misinformed, I'll just shut up and go away shall I?
:imoutahere:
scotjimland
2,324
10,062
A Woosh bang
:imoutahere:
No need to apologise, or the offence.... that wasn't my intention, so apologies if you were
If you know differently happy to be corrected..
the standard that applies to campervans is BS EN 1949: 2001 + A1:2013.
Key points detailed below:
