For context, I'm converting a Crafter to a camper. I have a bed over garage and I want to reroute the interior light to the garage so it comes on when I open the doors. I have already installed LED strips in the garage so all I need now is some electrickery to make the magic happen. I thought this was going to be relatively easy so I have buried a 2 core cable in the walls already to where I can join with the vehicle loom.
But this is where I ran in to some trouble. I assumed the interior light would have 3 cables coming in but I have 4.
This is where my knowledge is starting to fail me. Lp1 is a permanent live. It gives a reading of 12v against the chassis at all times. It's a red cable so this one I'm sure of. It is always connected to the bulb but it is also switched. G1 and G2 are gates. If both are left open the light doesn't come on at all. If G1 is switched allowing a connection to EIN then the light is always on. If G2 is switched then the light is only on when the doors are open.
The voltage between Lp1 and TK/EIN is always ~8v
Lp2 is the other side of the light bulb. No switches or connections to anything else. The voltage between Lp1 and Lp2 is either ~10v or 0v.
Having figured all of this out I thought, if I just join Lp1 and TK on one pole and Lp2 on the other I should be able to use that to my lights, but no. If I join them I get ~12v but then when I close the door it drops down to ~8v. 8v will still drive my LEDs. I'm pretty sure 8v is also enough to flatten the battery if it was left like that.
I'm stumped!
I'm stumped!
