I've been going through the electrics on my new to me Cl pegaso 62.
It has a panel above the gas rings that has a 12v power socket and various switches and indicators on it, I've worked out most of it
Press the button to show water and battery level's
switch for lamps above gas rings and sink
switch for water pump
switch for extract fan
and a switch with a symbol I don't really know, (picture below) it does operate a relay behind the fuse panel on a PCB. I'm not sure what it does but the LED is on all the time no matter which way the switch is turned.
I've removed the 12v power socket as I have nothing that will fit it as its only about 13mm in diameter, I am going to use the wiring for that to power a multi cigar lighter type sock for phone chargers etc and blank the old hole off.
Talking of 12 v power sockets I have found a 230volt 13 amp double socket powered from the leisure battery, OK they had managed to write 12 on the side of it, another wire from the leisure battery went to a cable with bare ends that were spread apart so the could short out. and the I found another very big cable direct from the battery via a 5 amp fuse that stepped down to a very small cable attached the rear of the drivers seat protected with a 15 amp fuse (go Figure) Ive removed it along with some other additions .
If anyone can point me in the right direction I'd be very grateful.
then I'll sort asking about the heaters, both water and air
