Electrical problem
derbys
AUTOSLEEPER SYMBOL
Leisure battery went really low last night and left me with no power.Drove it today and I think only solar charged it up.Fridge would not light up either (The red light) so no 12 volt when driving.Parked up now and on leccy hook up and battery is charging fine.Not looked and checked fuses yet..Do you think it could be just a blown fuse? BUSBY.
Alternator? Belt? When driving fridge is powered by alternator I believe.
Only by checking will show if a fuse has blown.
If you have a multimeter use that to check the fuse, not just a quick visual check.
Both fine.Vehicle battery is showing max charge.BUSBY.
Busby, then fuses must be your next port of call. As I am not familiar with your electrics, cannot help although I had a similar fault due to a poorly mounted fuse outside of the power supply unit.
Sorted thanks,,It was just a fuse 😀.BUSBY.
