Electric Drop Down Beds (1 Viewer)
Jul 30, 2013
18
12
Normanton, West Yorkshire
Coach Built
Since 2010@
I have a Chausson Suite Maxi 2011. The drop down bed is only coming down on one side, there doesn't seem to be anything snagging it i.e the spiral elect cable. The bed is now parked with a 30 degree angle on it and when operating the the buttons it all seems to be out of sync. when pushing the "up" button it comes down and vice versa and the only way to stop it going either way is the roof (up) and the seat base down or turning the power off. Can anyone advise please.?
andy63
4,672
15,018
south shields
since 1990
I'm not sure of your model or your control panel but there is a hiden switch on mine between the up and down button... not marked but can be felt if you run your finger over it...I believe it can be used to enter a programme mode...
I'll see if I can get some details if you still have problems....
It sounds more like a belt problem to me as I think they only use one motor to drive the belt set up...
If you strip off the mattress and slats you would see if the belt routing has gone astray...
Andy
andy63
4,672
15,018
south shields
since 1990
And I've just remembered you press the up button and the hiden button simultaneously for a few seconds to enter the programme mode...
Andy
I have no idea how these work but I can picture a wire wrapped around a drum, now if the drum turned too far it would wind out then wind back in and to you pushing the buttons it would appear they had reversed.
faraway
738
604
Kent
Chausson Flash 10
Getting better
My different model Chausson has a "reset" little hole on the up/down panel. I use a pencil point to push it in if required, which usually helps..
Steve N Tracy
1,237
3,759
Southampton
4 Years
Looks like the bed has been lowered down down to far and the belts have started to wind on the wrong way, as its on a tilt make sure non of the guide runner screws have come out and causing it to catch first, then lower it down on some cushions using the up button and keep it pressed until it goes up.
andy63
4,672
15,018
south shields
since 1990
Just in case it helps here's a page on programming but as has been said I believe there are different controls and mine is a 2016.
So if your panel is similar to this it might work if that's your issue.
Serendipity2
Jul 30, 2013
18
12
Coach Built
Since 2010@
thank you to everyone that has replied with suggestions to fix the problem. I didnt have much hair before this debacle but I have even less now. the van is now with Calder Valley Motorhomes for a bit of therapy and TLC. The bank balance might suffer though.
JJ
Mágica
May 1, 2008
19,260
48,076
Burstner Privilege T
over 50 years
I do hope you get it all sorted quickly and painlessly...
I am so very, very, very, glad I do not need electricity and all that it entails to raise and lower my drop down bed...
Classic Motorhomes Rool.
JJ :cool:
