PaulandChrissy
Hi Everyone
Thought I would do a little thread on the Fiat Ducato X250 and its windscreen scuttle leak problem, as I have been asked about it a few times. The problem is in fact THREE problems. I will go through them in turn.
1) Blocked drains in the scuttle which really is a maintenance issue. Keeping the drains clear is imperative and I know it’s a pain especially in the autumn. There are three in all. Two small ones at either end of the scuttle around the wiper spindles. They are very small and block very easily. Make sure the pipe on the back is not knocked off when you clean them as water will drip onto the back of the headlights. (Bad). If left unattended the drivers side wiper spindle will seize up. (Bad). The third hole is much larger and is easier to clean out. Located just in front of the driver next to the off side wiper. Once again make sure the drain pipe on the back does not become detached or broken.
2) Leaking at the joint of the two halves of the scuttle in the centre. This was intended to be joined with some stupid tape that always perishes. I have designed a drip catcher to overcome this problem by diverting the inevitable flow of water to a more non destructive position in front of the engine, rather than into the engine injectors. (Bad and expensive).
3) Water dripping onto the air filter casing and into the heating intake duct. This comes from the vent in the bonnet on the passenger side. The water seeps from the grilles in the bonnet down into the vent and accumulates around the rubber seal on the leading edge of the duct. This is pretty easy to deal with. Drill a hole behind where the rubber seal is, to allow the water to escape and drip onto the air filter casing. It will not harm the casing and just looks worrying, but its OK. When drilling the hole, make sure you drill it over to the right so the water doesn’t drip onto the wiring loom below. (Bad).
Hope this has been of help, as I am sure most people are unaware that there are three leaks as apposed to one. Some pictures are below hopefully giving you a visual feel to my ramblings.
Paul and Chrissy
Paul and Chrissy
