DT 220 control panel water senor not working properly (1 Viewer)
martinmonty
92
52
uk
coachbuilt
Hi I have DT 220 control panel on my frankia motorhome and the fresh water senior is showing full all the time I have cleaned the senor rods I have fitted a new senor sill showing full tryed resetting the control panel I believe the code for the frankia model is 6181could anyone come up with something I have missed before purchasing a new control panel also showing full when it's unplugged from the senor head thank you Martin
SandraL
1,373
985
Somerset
Hymer b694sl
Is the waste water level monitored by the same style sensor?
If so plug the fresh water sensor into the waste sensor cabling and check if you get waste water display. You could try the other way round.
Our dt201 panel has plugs on the rear to connect both water level sensors.
You could use a meter to prove continuity of the wires.
Have you got the manual for the display, available from schaudt via their website.
SandraL
1,373
985
Somerset
Hymer b694sl
SMC were very helpful and gave me my Frankia code for a EBL220 and a DT 220 B, it is 6181. I had also queried this direct with Frankia, they were initially reluctant to give it to me, but after a bit of discussion they did give me the code, the same one that SMC had given me. They did warn me to be careful with it though!
Seems 6181 is it, above copied from an earlier post on mhf.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Also remove the sensor plug from the panel completely. If the panel reads Empty with the plug removed the fault isn't the panel.
  • DT220C rear connections..pdf
M
martinmonty
92
52
uk
coachbuilt
Thank you all I have reversed the plugs and and it works but on full I have a triangular warning sign Martin I think it's the control panel
