Did used to be 8pm but now as it Anpr you can get 24 hr access. if the parking area is full go through barrier and plenty of room in overflow park on right. No ticket machines now so card payment on exit . .
Pretty sure you pay on your reg and the barrier is camera operated these daysSo what does one have to show on the bus, if asked?
You get a ticket as the barrier goes up on entry. Just show the ticket to the bus driver.So what does one have to show on the bus, if asked?
When we get one as good as this north of Watford Gap I would believe levelling up has started.
or cashNo ticket machines now so card payment on exit . .
You have to press button when entering if you want a ticket for the bus.So what does one have to show on the bus, if asked?
yesPretty sure you pay on your reg and the barrier is camera operated these days
except it is vice versa. A black waste that you can empty grey down. Look on the bright side you don't have a black waste outlet 6" behind the rear wheel meaning grate has to be lifted first then reversing so it is over the hole without wheel falling inThe only negative I have about the place is that you need to lift a heavy grate to empty your cassette - it goes down the same drain as the grey water.
