- Oct 19, 2019
- 55
- 94
- A Class
- I'm a newbie
Ours was from Smart Tow, some years ago (9) now so not sure if still in business (and a bit of a strange crowd). However aluminium box section. Very light and folded up into a carry bag to fit into the boot of our VW Up.Our A frame is from TAF. No jockey wheel but still heavy enough. They provided us a pair of triangles on a strap to put on the rear window. That makes it a trailer. No need for tow car or other signs.
You press the off button ?On our Aygo the “tv screen” for the radio, reversing camera, satnav etc. Comes on at the first detent on the ignition, even when using the “blank” (ie. no electrical i.d. Gubbins inside it) key. I haven’t found a way to switch it off yet......
Add a pair of triangles to the sides and jobs a goodunfit a pair of sprung number plate holders on the back of the towcar and it makes changing the number plate
Just make sure you remember to remove it when you get to your destination! Last week near York I asked Kathryn where the number plate was when we were fixing to head for home, it had been on the car for 8 days!! Oops!!fit a pair of sprung number plate holders on the back of the towcar and it makes changing the number plate a 5 second job
2 x Oblong Number Plate Holder Quick Release Spring Loaded Clips | eBay
Supplied as a pair, suitable to fit on most trailers that take an oblong number plate. WE ARE AN APPROVED IFOR WILLIAMS MAIN DEALER AND HAVE BEEN SINCE 1998.www.ebay.co.uk
push number plate up against the springs, lift out at bottom then replace with the tow vehicle plate. Just don't forget to change it back before using the car on the road by itself
You would do well to remember the more expensive A framed cars command a much higher sale price and have a larger 2nd hand buyer market due to the lighter weight if nothing else, losses will easily match your suggested unsaleable Inertia system,There're 2 main types of A frame. One with just overrun brakes just like a caravan or some with a full electronic braking system. The full electronic versions come very expensive in my view around £2k. An overrun brake system as supplied by Armitage is probably just about £500. Why pay £2k over the odds for a little car which you will never see back again. I bought a second hand Armitage overrun A frame for a Citroen C1 and converted the car myself so I am only out of pocket by less than £500 after buying number plates, electric cable, plugs and sockets etc. That I can afford to lose if and when I have to sell the car and can't find a motorhomer to buy it!
Good move why put up with an inferior product, get your use out of it and sell for a better price to a bigger market see reply above.Might not be possible now , but decision in our house (at show) went i dont like the price £1000 THATS better, ok pick it up and put it the boot. She decided on the smart tow system. I never think about what i can sell it for my intention is buy the right one and use it untill its dead.
I fitted a jockey wheel to my a frame , it allows moving of car without frame being elevated also helps hitching up either by driving up to tow ball or reversing motorhome onto a frame.
One other advantage is that in the unlikely event of a frame separating from tow ball it would not drop and potentially dig into road surface allowing braking system to stop car effectively.
That is why trailers have to have skid plates to prevent that happening.One other advantage is that in the unlikely event of a frame separating from tow ball it would not drop and potentially dig into road surface allowing braking system to stop car effectively.
On our Peugeot 107 , we have key without transponder and you put key in and turn on fully and then back off and as long as you don’t take key out, everything is off and steering lock is off.On our Aygo the “tv screen” for the radio, reversing camera, satnav etc. Comes on at the first detent on the ignition, even when using the “blank” (ie. no electrical i.d. Gubbins inside it) key. I haven’t found a way to switch it off yet......
Having towed caravans and boats using the overrun system since my youth I’m happy with what I’ve got and no doubt there will still be people around with the same view when I’ve finished with it!You would do well to remember the more expensive A framed cars command a much higher sale price and have a larger 2nd hand buyer market due to the lighter weight if nothing else, losses will easily match your suggested unsaleable Inertia system,
I have a sequence and double check every connection etc when complete. I refuse help of any kind from others when setting up as the only time I got help I missed the setting up sequence on the RVi Brake unit and ended with extremely hot discs after a couple of miles, could have been nasty.I make a list of to do,s when coupling up. Otherwise I usually forget to do something.
Phil
Seems to me if that were to happen you would be well buggered anyhow!That is why trailers have to have skid plates to prevent that happening.
We replaced our hernia inducing Car-A-Tow with a much lighter TAF one, it is a nicely engineered bit of kit. It is not the longest A frame so take care on tight manoeuvres like U turns, the car can end up very close to the back of the motorhome.Our A frame is from TAF. No jockey wheel but still heavy enough. They provided us a pair of triangles on a strap to put on the rear window. That makes it a trailer. No need for tow car or other signs.
I would agree with your comments if you were using Caravan/ trailor inertia hitches but you not are you, the all important legally required ability to revers is not fitted is it?Having towed caravans and boats using the overrun system since my youth I’m happy with what I’ve got and no doubt there will still be people around with the same view when I’ve finished with it!
You obviously know far more about it than me but you are reading more into my post than was intended. I was loath to part with a £2k premium to try out towing a car. Maybe I’ll become a convert to the all singing all dancing versions in due course.I would agree with your comments if you were using Caravan/ trailor inertia hitches but you not are you, the all important legally required ability to revers is not fitted is it?
If it were i would be with you 100%.
Having owned, fitted and built all manner of A frames i do know which is the better system.
Despite you missing the entire reason for my comments to you post that being, the fully electric versions will loose more money than the overun type.
I still believe your prophesy to be wrong and if any action from the powers to be should happen it will be firmly aimed at the DIY and overrun systems
heralding their earlier demise.
