DOMETIC PERFECTVIEW CAM 80CM
bilM
Aberdeenshire
I'm a newbie
Hi I still have reversing camera problems. So what is happening? I start up put it in reverse and I get a blank screen. If I disconnect the block connector on the MP100 and then plug it back in the reverse part of the camera works and stays working, I can go in and out of reverse and it works. If I shut down and start up again, I get a blank again. The ( see what is behind you works fine). I have taken a video so you can see what I mean. Any comments and suggestions appreciated. Domestic PerfectView Cam80.
My guess... After seeing vid... Software issue/glitch?...
Btw. I have no knowledge of reversing cams... But would consider it as possible cause.... if it was mine and all other stuff seemed ok...
I would then look to see if firmware could be reinstalled/updated.
