Anyone out there can you help, dometic Fridge not cooling.
Need more info???Anyone out there can you help, dometic Fridge not cooling.
Hi everyone, it was very hot here today, its not really cooling at all the freezer part is very cold, gas wasn't working properly, I've been on 240v all day.
In that case you will need to fit fans to ventilate the rear of the fridge. Paul is just showing off with his three fans. We find two will do. We got a kit complete with thermostat and an automatic setting so it was nice and easy to do. Always install in the top vent with them sucking the air out.Hi everyone, it was very hot here today, its not really cooling at all the freezer part is very cold, gas wasn't working properly, I've been on 240v all day.
Hi could you direct me to where you can buy such a kit please?In that case you will need to fit fans to ventilate the rear of the fridge. Paul is just showing off with his three fans. We find two will do. We got a kit complete with thermostat and an automatic setting so it was nice and easy to do. Always install in the top vent with them sucking the air out.
Gas is usually better than 240v electrics with with an absorption fridge. You may need to clean the gas chimney or it could be a blocked jet.
I bought the CBE Kit, which you can get on Amazon It has two fans speeds, and you can either switch it on manually or let it work automatically with an adjustable temperature sensor, which is what I do. I bought it from a Dutch company (can't remember the name) because it was cheaper, but it took a while to deliver. The switchgear matched the switches and sockets in my Hymer, which are also made by CBE.Hi could you direct me to where you can buy such a kit please?
You may have one or two problems. If it is not working well on both electrics and gas and the weather is hot then the problem is probably that the fridge does not have enough ventilation at the rear. They are all the same in the middle of summer in Southern Europe. To help it you should take both vents off. But that will probably still not get the beer cold enough so the only long term solution is to fit the fan kits mentioned in previous posts.Gas is fine the cooker and bbq ate working perfectly of the gas.
What cut-in temp are yours set at ? I've mine at 30º but obviously they are on nearly permanently.Was thinking of raising the cut -in ?Our fans are on all day here in Spain but they cycle on and off at night
About 42c but the thermistor is in the last condenser fin on the left hand side...What cut-in temp are yours set at ? I've mine at 30º but obviously they are on nearly permanently.Was thinking of raising the cut -in ?
Is the hole big enough to accommodate a couple of 100mm square fans? If so they could be mounted horizontally on the ceiling. Otherwise I suspect it will have to be on the bottom vent blowing in rather than out.My motorhome has a roof vent so fitting fans will be little bit different. Any advice on roof vent fans would be appreciated.
I was puzzled why I had a roof vent instead of the more usual upper side one, so I did a bit of digging. It seems the roof vent is for use where an awning might be fitted. The inference is that having the upper vent below an awning is seen as a problem, though I have not found the official reasoning. I would guess that the awning could trap still warm air that would interfere with the flow from the upper vent.
As for why the roof vent is fitted, it seems to depend on the converter. The majority of continental layouts seem to have the fridge on the habitation door side, which is also the side for the awning. Cathargo seem to use the roof side quite a lot, whereas Hymer rarely do.
Those are very expensive & don't work very well compared to fitting a couple of fans to the top vent.Dometic do a kit that fits to the back of the fridge and blows upwards across the hot bits. It is thermostatically controlled by the temperature of the fridge pipe work.
Dometic Fridge Ventilation Fan Kit - RM4 to RM9
shop.caravanclub.co.uk
It depends on where your sensor is and the fridge installation.What cut-in temp are yours set at ? I've mine at 30º but obviously they are on nearly permanently.Was thinking of raising the cut -in ?
Lenny, I think you have the internal Fridge fan also?, Where did you fit the thermister for that, I was thinking ideally half way down the right hand side of the fridge, is some sort of white trunking to hide the wires.Those are very expensive & don't work very well compared to fitting a couple of fans to the top vent.
My sensor is on a strip of aluminum between the fans on the top vent. I find I get best results if I can set the fans to come on when the ambient temperature is 25 deg. On my current van this means setting the controller to 32, last van with a similar install it needed to be set to 35. I also set the controller for an hysterises of 2 deg.
