Do you grease your balls (1 Viewer)
Mikey RV
4,532
22,149
Devon
Burstner Elegance I821G
Since 1977
Towballs that is before you lot go off getting excited or suggest this is the wrong forum. Got into a discussion with a guy towing a toad. He said he puts grease on his towball, another guy said he uses nothing. I said I use nothing but do occasionaly spray some white grease on or some silicon grease. What do you do with your balls. Remember this is a family forum. (y)
old-mo
Extra Special
16,309
92,015
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Regularly.... :giggler:
I was told not to... but always wipe a little over just to stop it going rusty... :happy:
May 7, 2016
6,594
10,282
West Sussex
Carthago Compactline
Since 2003
I don’t grease it because it makes removing and fitting it messier. It lives in a bag in the garage when not in use. However I do wonder if I should grease it occasionally.
funflair
18,883
28,959
Guisborough
MORELO palace
since 2012
I think the "no grease" comes from caravan couplings that use spring loaded friction pads on the ball as a stabiliser, obviously grease is not good for friction.
If it wasn't a friction pad I would grease as they can and do wear and at the extreme they can become detached.
Martin
Nov 4, 2011
5,671
38,720
Uk
I don’t but maybe a smear of an oily rag wouldn’t hurt :confused: and if you ever use a Alko tow hitch with anti sway, you should never use grease on them.
Aug 19, 2014
1,809
5,314
Cliftonville
A Class Burstner
Since 2014
Am married to a Beauty Terrorist..... Greasing is the least of my problems.....
wasp
1,724
18,180
Warsop
None gone caravannin
I keep a cover on mine so not necesary
Lenny HB
50,044
137,557
On the coast in West Sussex
Hymer B678 DL
As Martin says if you have an old fashioned hitch you grease the ball otherwise the ball will wear, suprising how quick they ware if not greased and get dangerously undersize. With a stabiliser hitch you must not get grease anywhere near it or the stabiliser won't work.
tuscancouple
552
964
Kent
None
As Lenny said, it's two metallic surfaces in contact. To reduce wear it is essential to lubricate and a smear of grease will do nicely. So if it's a toad or trailer behind then it should be lubricated.
If it's a friction coupling such as a bike rack, then any lubrication would not be good :)
All depends on what's attached to the towball.
Mick
Gellyneck
8,991
17,642
Scotland
More than toes wet now!
When we had a caravan with Alko tow hitch towball was cleaned every couple of weeks with a rag and some brake cleaner to ensure friction pads remained clean.
Now we only drag a garden trailer around so towball is greased for the reasons above.
Mar 23, 2012
9,086
29,655
sleights
c class
As all the others have said. It was a pain when we were tuggers the ball needed to be clean for the caravan hitch but when we put the trailer on the car grease from the hitch would contaminate it.
Aug 18, 2014
22,540
120,959
Lorca,Murcia,Spain
Transit PVC
6 years since restarting
One school says grease/oil them the other says the grease/oil attracts dust ,especially here , & creates more wear.
Northernraider
25,728
150,348
On the sofa ....
Hymer 654
On and off since 95
It used to be standard apprentice initiation in the motor mechanic trade
But when the world went pc it became a disciplinary offence so probably not
Oct 7, 2013
5,743
35,949
South Wales
Swift Escape Compact
Since 1988
We have a standard hitch for towing a small trailer carrying our scooter and keep it greased to reduce wear to the ball and tow hitch.
When the trailer is not in use the tow ball wears a cover to protect from the grease.
Apr 13, 2012
5,396
18,529
Mobilvetta Euroyacht
1996, then break 'til 2011
I fit a white aerosol can top on mine with the reversing camera aimed at it - it makes reversing easier. If parking up I leave a 'marker' on the ground to help when returning.:)
PeteH
6,853
9,029
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
PLEASE!. :cry: Don`t go there The image is forever etched in my mind, Engineer`s "Blue" takes forever to remove.:cry:
