DIY on LPG? (1 Viewer)
R
Robert Clark
Hi Guys
Considering fitting GasIt refillable bottles myself. Also a BBQ connector which would require cutting into the 8mm copper pipework running from the regulator.
Have lots of plumbing experience so am not concerned from a practical aspect.
My only concern is if legally I can do this work?
Regards
Robert
2,327
10,087
yes you can .. there is no statuary requirement to be an LPG accredited gas fitter to do work in your OWN van
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
When you do it please post photos of the installation.
I have no qualms about fitting the system - have done gas filling in a previous house prior to the regs coming in - only leak was much later where a professional had fitted a new gas hob incorrectly, boy was that dangerous. The leak was on his new pipework not mine.
When you do it use leak detector and check, check, check again.
Don't put the filling point on the door to the locker. You do not want to move / flex or interfere with the pipes in any way once they are fitted and leak free. Test for leaks on a routine and regular basis.
R
Robert Clark
Decided to let a professional mobile MH engineer fit the BBQ point. He quoted £120 to fit, including fitting the GasIt bottles. Not bad considering he's going to take responsibility for cuting two BIG holes is the side if my new MH. Plus I get a test certificate to show that there we no leaks. Plus I've made a saving of over £300 on what my local dealer quoted to do the same job using gaslow.
Fitting should be next week and I'll let you know how I got on.
Regards
Robert
Feb 16, 2013
19,734
52,021
uttoxeter
ambulance conversion
50 years
This is my gasit bottle installed, as you can see just like changeing a normal calor bottle
Apr 23, 2014
672
861
Spain ??
Ice cream van
Since 2011
Fitted mine a couple months ago ! as previously stated thoroughly check for leaks
2x 6kg bottles with auto change over and outside fill point .. to fill £17.50 definitely worth doing used to cost £20 just to refill one 6kg bottle
I also fitted BBQ point Broken Link Removed with inline 8mm Valve Broken Link Removed and Copper pipe Broken Link Removed
All in all about 2hrs install with a couple tinny breaks (y)
Hope the pics come out to give you some idea
D
Deleted member 29692
Hi Guys
Regards
Robert
I fitted my BBQ point myself. Sorted myself out with all the bits, 8mm plastic coated pipe, 8mm tee etc. Cut the pipe on the MH and discovered it's 10mm. Took a couple of days to find a 10/10/8 tee.
Wetfoot001
4
5
Staddiscombe
Low profile
A few years
I'm in the process of fitting a refillable underslung LPG tank to our van (ALKO chassis). I had a quote of £500 (for installation only) from a mobile fitter to carry out the work, after local motorhome dealers shied away. I decided the plumbing (all external) is simple enough to do myself. I have purchased an 8mm Truma CGA 1054 electric remote isolation valve to shut off gas when transiting.
We had an odour of gas in the gas locker since purchasing the van which maybe down to the Calor Lite bottles recently exchanged under the recall. Once we have had the habitation check renewed we should be sound for the next continental tour.
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
This is what i did to mine,
Bailey58
8,816
29,570
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Any update on your fitting Robert? And a general question for others, am I right in thinking it better to have an external filling valve, particularly for Europe and their apparent dislike of us filling for domestic use?
32,656
66,555
Some will tell you to have an external fill point due to 'problems' but we haven't had this. We've had a system with the filler in our gas lockers since 2009, and in our current PVC we have to actually open the back door and then the gas locker to do it, so it is quite obvious what we're doing (and have been for well over 2 years) - we have used it extensively both here and abroad and have NEVER been refused filling! If it is easy to fit it externally then you might as well do so but as you have to ensure that the gas cylinder(s) is turned off before filling unless you travel with it turned off, you'd still have to open the locker to turn it off before filling anyway.
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
Was refused filling last year at the local Shell station as it was an in locker fill point. Pointed out the system but no dice - "more than my jobsworth". Now fill at BP station instead
32,656
66,555
Just to get a real feel for this, how long have you had your system and how many times have you been refused?
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
Hi,
Fitted a new gaslow system about 5 years ago to the first van with an external fill point and never had a problem. Moved the system to the last van but had a fill bracket in the locker between the two bottles. No problems until the local Shell station refused a fill last year based on an apparent edict from head office (maybe.....). Filled up at BP instead without issues. Fuel as well.........
Shell are known to take a zero compromise attitude to HSE and perhaps this is part of it. Only the one incident but it put me off Shell filling
