Worth a punt! I appreciate the heads up. Do you happen to know what the deflector is exactly or where to get it? Ta
Fiamma do one called drip stop but some also call them rain stop or door/rain gutter.
Fiamma do a drip stop which comes with or without a light fitting built in. I had to replace mine when it got ripped off when in a narrowish road by tree branches. This was couple of years ago, the replacement is self adhesive which has survived so far.Fiamma do one called drip stop but some also call them rain stop or door/rain gutter.
How old is your van? We have recently taken delivery of a brand new 680 G and on its first outing we encountered biblical weather in Norfolk which involved driving through semi flooded roads. After a few days on site I decided to lift the bottom step mat to shake off the muck. It is a stiff carpet top with cork backing. Underneath was awash and the mat was wrecked. Could not identify where the water was coming from. When we returned first job was to put in the dehumidifier to dry out what was trapped below the step. On inspection underneath I found the culprit. The step outer casing is sealed to the underneath with mastic ( administered by a fitting alchoholic I think), and there was a nice hole in the mastic allowing any water driven up underneath to enter between the casing and side wall.We have a plastic door mat inside the hab door of Burstner van and sometimes when visiting the van in storage there is water under the mat, no where else, though there is a highish damp reading of 25% on the bottom of the hinge side wall and under the hab door where the wood has actually rotted. We have not witnessed any water penetration while using the van. You'll see from the photos that the inner black rubber seal is not tightly compressed to the frame on the hinge side as it is everywhere else. There's no visible light getting through but pressing the seal slightly with fingers easily produces a gap. Can't see any way to adjust the door. Could it be in times of heavy rain and wind, water is pushed in and on reaching the bottom is trapped and so spills over inside or something? Are all hab doors like this? Thanks for any input!
View attachment 432287View attachment 432288
Fiamma make rain guttering which worksI don’t know what it’s called, but Chelston’s and Newport caravans are familiar with the item as they have fitted the “ rain deflector” to my Burstner A class.
In conversation with the dealer, I was of the opinion that they are aware of this scenario.
Have a go, it’s worked for me, twice!
I'll check it out, and thanks for the link. Self adhesive sounds good to me!Fiamma do a drip stop which comes with or without a light fitting built in. I had to replace mine when it got ripped off when in a narrowish road by tree branches. This was couple of years ago, the replacement is self adhesive which has survived so far.
It's 2014 and if it is the door seal being in the 'wrong' position, then I'm guessing it's been like it since day one, but never see any water on the floor, unless it's under the mat. I had been blaming wife for not drying properly after cleaning . I don't have an internal step but will look under the van anyway. Thanks.How old is your van? We have recently taken delivery of a brand new 680 G and on its first outing we encountered biblical weather in Norfolk which involved driving through semi flooded roads. After a few days on site I decided to lift the bottom step mat to shake off the muck. It is a stiff carpet top with cork backing. Underneath was awash and the mat was wrecked. Could not identify where the water was coming from. When we returned first job was to put in the dehumidifier to dry out what was trapped below the step. On inspection underneath I found the culprit. The step outer casing is sealed to the underneath with mastic ( administered by a fitting alchoholic I think), and there was a nice hole in the mastic allowing any water driven up underneath to enter between the casing and side wall.
There was black mastic hanging like icicles from the van underneath, it is used with abandon by Burstner.
pdi’s are superficial that is apparent as there are quite a few issues in need of attention. Nice van but BMW it ain’t
That's helpful - one seal issue does not detract from the build quality of some German vans.Sorry in advance for taking advantage of your bad luck but this seems another example of the much vaunted build quality of 'premium' German m/hs
I have bought a german van myself and but im just saying that i seem to read as many threads on here about faults with german manufacturer's as any other.That's helpful - one seal issue does not detract from the build quality of some German vans.
Regarding build quality of vans, in my case I look at the various issues and none reflect on the quality of the product just the attention to detail. It’s our second Burstner and both have/are been great units, buying a new unit at a considerable cost there is an expectation that either the factory or dealership pdi would pick up the issues. Apparently not. Maybe it is down to that mass purchasing of motorhomes this year that some inspection procedures have suffered, I can only speculate. As an example, the awning is factory fitted and betweenIt and the side of the van at the top they put in an expanding seal which expands once the release tape is removed. The seal if fitted correctly should expand down behind the awning. Half way along ours blooms out of the gap so you have 3m of black foam stuck up in the air. Pretty ugly, impossible to clean and releasing black marks down the van. This escaped the attention of both factory and dealership and will probably result in the awning have to be removed as part of the remedial work, a major job.I have bought a german van myself and but im just saying that i seem to read as many threads on here about faults with german manufacturer's as any other.
Is it still by any chance still under the water ingress warranty?It's 2014 and if it is the door seal being in the 'wrong' position, then I'm guessing it's been like it since day one, but never see any water on the floor, unless it's under the mat. I had been blaming wife for not drying properly after cleaning . I don't have an internal step but will look under the van anyway. Thanks.
You know I never got a straight answer to the ingress warranty duration, but sure it's now expired anyway Lenny.Is it still by any chance still under the water ingress warranty?
Tooooo much info! Don't worry we won't tell!Double seal on mine as well. The door is so heavy that it sounds like a prison cell door slamming.
Cant grumble at our Knaus it’s brilliant!Sorry in advance for taking advantage of your bad luck but this seems another example of the much vaunted build quality of 'premium' German m/hs
Yes, same with the likes of house roof leaks. Where the water appears isn't necessarily where it's getting in. I had a car and one rear light cluster would get water in it. Turned out a gap in weld under the recessed roof gutter. The water must have clung on all the way down the inner slope of the hatchback area.Sorry to make it sound worse. Hopefully yours is a simple fix but my 2005 Scout had a leak accumulating in same area. Similar damp test results. I replaced my seal. Removed and resealed my door. No joy. Realised it only accumulated there when parked on sloping drive with the front higher than back. Damp checked all wall behind fridge and cooler etc. Checked kitchen window seals which were further forward than door. Replaced fridge vents and seal to external gas tap. Working my way forward. Wasn’t any of that. Eventually found and sorted the issue but it was the seam on the Joint between hab and cab area. Resealed the joint cover and it stopped happening so it can come in anywhere and end up somewhere else. Good luck.
I'll give it a try next time I go to storage though not sure I'll get any left to right movement to move door towards hinge side.As M-J said slacken off the bolts on one hindge and see if the door can be moved it's only clamped on place. Might give u enough movement to create a seal.
Dont take the bolt out completely and dont use to much brute force and bend the door frame.
That sounds a serious bit of work!Measure the actual hole that hey made in the bodywork. My hymer leaked like sieve into the garage and flooded the floor everytime it rained. I fixed it myself an found the factory had spread the rear face away from the front when they fitted the floor panel. It was so far away you could see through the gap. The dealer wanted t fit another door an have it fo months whilst doing it. I was not going to drive 300 miles each way with two vehicles twice just fo them to do a not needed , repair to the wrong thing . Took a bit of thinking about bu I was successful anf it took a days work to reset the side panel, but my Hymer warranty was cancelled or so I was told, because of unauthorised work being done by a non agent, me. the sorr ytale is on the forum, away back in the past.
Adjustment may be possible up and down but I reckon I need sideways. Seals look ok as far as I can see.Can the door be adjusted?
Are the seals fitted correctly?
How can I tell make of door? Haven't seen anything obviousThere should be adjusted on the hinges , Had a similar problem with a Hartel door with wind but no water
Current MH has a seitz door no problems
Yep, sameOur Burstner seemed to have two settings for the door closure. Pull to to close the door or slam it shut if you wanted it to close properly without drafts etc.
we had the same problem last year and were racking our brains as we had not had any water in van before. Our door mat was almost floating and whenever we dried the step more water appeared. Fingers crossed we think and hope we solved the problem. The rubber seal on the right hand external side of the door has a join near the lower hinge. This had popped out of position and was acting like a funnel everytime it rained. Just pushed it back into place and we haven’t had any water in since. We do keep an eye on it, but so far so good.
