Daylight running bulbs
Spain
Autotrail Navajo
Hi all, does anyone know what these bulbs are and where I can get them? Had a good look around but can’t seem to find them. Are they sold individually or as a complete unit?. Thanks in advance for your help.2015 Autotrail.
Try looking at this post on this forum
Daytime Running Lights on Pilote Galaxy​
Might help you
They look a bit similar to the ones on our Carthago which are made by Hella. If they are they are sold as a complete unit, but the old ones that still work should be saved as they could be spliced in if one fails again.
Can't find a link at the moment but we got a set for both sides for around £50 a few years back.
Will keep searching.
Might help you
Link not working
Might help you
#18 in this thread has a pdf of the DRLs I used.
#11 in this thread.
Apparently no longer available due to age of van! 2015😕
That's a bummer!
If you do happen to locate a set this thread gives some insight on how to replace / install.
That's a bummer!
After posting previous just had another look at the linked thread and was wondering if you could get the available sets of individual bulbs / wiring tails and either connect them up in series or parallel?
pappajohn given your input on attached thread above any thoughts?
Think i would be looking at something along these lines
Link
Thanks for that I will have a look. Just found out that as it is pre 2018 it is not part of the mot . So no panic as it is due soon .
My Dethleffs got thru an MOT with one of the five out.
From memory so could be a heap of pi....... and the first point may not be relevant to yourself but I think
  1. DRL's are only tested on vehicles first registered from March 2018 and
  2. it's only a minor defect (not a fail) if 50% or greater of the lamps are working. It's a fail if over 50% faulty.
My understanding is if lights are there they must work ....but I could be wrong
1 of my 5.5 tonne lorries has lamps fitted but they don't work and that's passed 2 mot,s
