Cycle Electric Assist
Clickem
Northumberland
None
7 years
I bought a couple of small sized electric folding bikes a few months back from a company in the midlands, that I know a lot of Funsters have also had dealings with. We don’t use the bikes much, but after about 2 months the pedal assist on one of the bikes stopped working
The supplier thought that the pedal crank sensor was the likely culprit and sent one, that I fitted, to no avail. They then collected and repaired the bike. Two months or so later, we are in Spain, and the same fault has developed again. I reported this to the supplier about a week ago. Today the second bike has also developed the same problem, so we are left with two electrically assisted bikes, that are not
I post this to ask if any other Funsters have had this or similar problem with these bikes. If so please would you be kind enough to click on my avatar and start a conversation with me
I would be happy if no one replied to this message, on the open forum, and used a private conversation to discuss the matter
TIA
We might have the same bikes. Bought 2 no problems so far in fact they are great. A couple of times the cables have separated on the electric side when unfolding my fault. Just pushed them back together. Could this be a problem as there are a couple of joints that could be loose and bike won’t work. Just a thought
Check the battery connector (if it’s a removable battery) is making good contact, clean the terminals with an ear bud and alcohol. My Ebike and a friends suffered this, it was fixed after the connectors where cleaned.
You don't have a little magnet clamped on a back wheel spoke with a receiver, cable tied to the chain arm do you ? Our leccy bikes have this and if it gets slightly out of line (If the bike falls over for example), it stops the assist working.
