There was a recent thread regarding the above posted i believe by @MisterB have tried sending a PM without success, hopefully he will pick this up. In the meantime does anyone else know where he had this installed?
Thanks.
Not being rude but how much did it cost you.Just been quoted £590 plus VAT which I thought was over the top.BUSBY.Only just seen this but someone has already sent the details. He will come to you aswell if you pay travelling costs. If you can get someone else local then you can split the travelling.
Mine was done about 6 weeks ago and i am really pleased as it is identical to factory fitted cruise control and works fine.
Ps i didnt get a pm ... ?
Might be worth checking your settings ?Ps i didnt get a pm ... ?
It cost £220 in total. There may be aditional cost depending on base vehicle. I dont know how good the system is you were quoted for, it might be a much better system so i wouldnt want to make comment on the justification or otherwise of the higher quote. I am more than happy with my cruise control.Not being rude but how much did it cost you.Just been quoted £590 plus VAT which I thought was over the top.BUSBY.
It is on the 2007 Ducato, but you need a star box to add it to the ECU ( at least I did ! )Is the wiring to connect the cruise control already on the 2006 onwards vans as may be possible to retrofit kit yourself ?
Was it easy to fit i guess they supply the fitting instructions? cheers mattOurs is a 2013 Peugeot Boxer X250 and it was a doddle to fit this one, see post #1194
https://www.motorhomefun.co.uk/foru...xed-on-your-motorhome-this-week.70246/page-60
Cheers you make it sound so easy What could go wrong!!Yes, easy to follow instructions, 3 solder joints, fit the throttle pickup plug (plug it in) near the throttle pedal and fit the new stalk and plug that into the supplied control box, run through the system test procedure and job done.
