had exactly that problem on our 2012 adria about 18 months ago.I was washing the van yesterday and noticed the black graphic above the windscreen was cracking. Looks like I will need to do something about it in the not too distant.
How easy are these graphics to remove?
Does that make it more difficult?PS. i just realised you have a PVC so yours is attached to painted metal as opposed to the gell coat of the GRP section of overcab.
I purposely keep old debit and credit cards to use as scrapers for this sort of thing.
I use one of these to remove decals and graphics.
Stripe Removal Decal Removal Wheel Fluted Toffee Caramel Drill - Heavy Duty | eBay
HEAVY DUTY FLUTED GLUE REMOVAL WHEEL. FLUTED TO PREVENT HEAT BUILD UP. USE WITH THE FREE DRILL ARBOUR SUPPLIED. sticky glue residue or double sided tape is left on the panel a fter removal of badges, body trim mouldings, always a pain to remove.www.ebay.co.uk
I enquired about that.Wonder if it would give an acceptable finish and easier just to put another decal \ vinyl over the existing one?
Looks good. And, I think South Wales is just toooooo far away from North Hampshire!This is ours after I removed it and did not replace it.
Are you sure it’s a decal? Or painted on? That’s what I’m not sure of as mine has also discoloured a bit and is now a mat finish.Interesting as my 2009 Adria (A class) has a similar decal which has faded to a greyish colour & I can't get up high enough to see if there's any cracks. The red gel 'A' has lost all the colour as well.
I was thinking satin HammeriteWonder if it would give an acceptable finish and easier just to put another decal \ vinyl over the existing one?
