Correct tyre size
Jaspersmate
Van Conversion
Hi I have an Autocruise Alto 2015 model with 16” wheels, I want to renew the wheel nuts which are very rusty and also include locking it for each wheel. Are the wheel nuts or studs a different size to the smaller wheels or to be precise what size diameter wheel studs do I need
Hi Phil, I thought most people would know its only available on a Fiat Ducato chassis, how do I add this to my original message please.
Others may know but its not obvious.
You can edit the post by the bottom left markers
I certainly did not know
The studs are the same regardless of wheel size but alloy wheels have different studs to steel wheels i believe
Errrrr.... My Maxi chassis has 16" wheels (all Maxi chassis do I think) and i recall the bolt heads are 24mm (i.e. not found on your usual multi wheel brace, one size bigger).
i think you are correct that the 24mm is the socket size for the stud heads the shank which i believe the OP wanted is 14mm i believe.
