Copper Cable Source? (1 Viewer)
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Having worked out that I need 2 x 4mt of 10mm and 2 x 4mt of 25mm can anyone point me towards a sensible price and source please.
Thx
Bernie
2,373
10,311
I've used this company for cables, terminals etc
Autowbars
500
297
Yorkshire
Lunar Roadstar 800
r you sure about 25mm, that is TOO BIG for domestic use and is VER HEAVY, capable of 1000s of volts, amps
Apr 22, 2013
911
661
Cotswolds
Bailey Approach 625
Since 2011
I too have used Vehicle Wiring Products and can recommend them.
But for smaller quantities try Amazon, search "25mm battery cable" there will be several options.
R
Robert Clark
Loads of it for sale on EBay
Short and long lengths
Have used eBay a few times for cable and battery connectors
All good so far
Ber090
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Thanks to you all for your replies. The cables for interest and comments are:
1. 3 x 100watt solar panels via 30amp mptt reg ( when it arrives from China) 10mm cables to batteries is what comes up for 4m run with 3% loss.
2.Inverter 1000w pure sine wave 4m run to batteries needs 25mm so the cable size charts say!
All square section. Thx Dave!
Happy for any other suggestions.
Cheers
Bernie
2,373
10,311
actually .. at 12v ... 4mt run the capacity is about 50amps
edit ..pipped to the post
Bernie
The beauty of an inverter is 240V out, so little cable loss. So, if possible, put inverter next to batteries and run small 240v cable the long distances.
Ber090
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
BER090, I'd suggest you put your inverter as close to the batteries as possible and run a 230V lead from it to where you want the power.
D.
Thx Dave but my Aviano 728 is a nightmare to find space for the inverter. Only option at present is inverter in garage
Cheers
Bernie
Nov 6, 2013
1,416
3,171
S. Ayrshire
The usual
Since the beginning
A 1Kw inverter will take 85A at 12V. Assuming you want to stick at 3% volt loss, my cable calc give a CSA of 50mm2
Unless you have access to a hydraulic crimper, you'll have difficulty maintaining 3% loss.
I'd recommend shortening the cable runs - inverter as close to the batteries as possible.
What rating are your leisure batteries ?
11,957
16,571
25mm2 is tiny stuff, try working with multiple pole 400mm2 cable (y)
Cover your 400 & raise you to 7,200mm2 aluminium. I saw a 15" Stilson dropped across a pair of those carrying 50v. The Stilson and both busbars melted. It covered the place in molten aluminium. It was very exciting (from a distance):eek:.
Nov 6, 2013
1,416
3,171
S. Ayrshire
The usual
Since the beginning
We only go as far as 400mm, as anything more is too difficult to work with - bend radius alone is a non starter ;)
Have seen all sorts dropped across DC (54V) busbars) - non last long :rolleyes:
Ber090
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Hi Gizmouk, Batteries at present are 2 x 110amp. 3% is not critical and would prefer to use 25 not 50 for obvious reasons. I doubt we will ever get near full load. Getting shorter run would be great but struggling to find a way.
Cheers
Bernie
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Bernie, what exactly do you intend to run off this inverter? I ask because you say you dout you'll get close to its max load. Worth considering that most inverters are only close to their quoted efficiency at round 75% of max loading. As the load moves away from that 75% area the efficiency often drops off at an alarming rate. If you don't actually need to run a 750 Watt load from it then rethink the size of inverter you need. Look at your 230V requirements and get an inverter that will give you that wattage at max efficiency.
D.
Ber090
Ber090
807
2,560
West Yorkshire, UK
Autosleeper Warwick
Hi Dave, I take your points. Most of the time we will run kitchen gear at 150 watts etc. The Boss wants to get a 750w microwave for occasional use.( I make no comment!) Bottom line is that we have the inverter already and as we intend to keep this van for a long time it probably makes sense to us to over cook if you get my meaning.
Cheers
Bernie
17,639
43,425
as a general rule of thumb the startup current for a microwave is double the rated output
PeteH
6,853
9,032
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
sparky
97
85
bingley yorkshire
a class burstner aviano i
30 years
Hi I have the aviano 726 the 2 batteries live in an outside locker the 1000 watt inverter is fixed to a thin piece of plastic and wedged on top of the 2 batteries which keeps cables very short (12 volt ) and a mains socket run into van along with the remote switch to turn it on and off
