Control Panel (1 Viewer)
rich g
480
855
Worcester
A/S Warwick
since 2013
The control Panel above is not working it won't turn on I just get a blue light flashing in the top right slot ,I have connected it to electric hook up and same result,so I have no power. Any suggestions please
rich
Many times in the past people have been told "remove from wall, unplug, wait a minute, plug in and try again".
You could also check your leisure battery volts first.
K9Brian
575
South Manchester
Since April 2010
Give Sargents a ring - they've been excellent talking me through problems. If possible phone from the van in case they ask you to try certain tests.
rich g
rich g
480
855
Worcester
A/S Warwick
since 2013
I rang Sargent and they told me the light was flashing because to much power was going into the battery and the power was stopped to protect the battery from frying
So they said cover the solar panel and if the control panel returned to normal the regulator on the solar panel is not working.
I have just had a tow bar and electrics fitted is it possible they caused the problem or is a coincidence .
Aug 18, 2014
23,806
133,946
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Can't really see how having towbar electrics fitted could cause it ? Probably a coincidence.
23,836
72,555
Do as Brian Said.. remove from wall, unplug the ribbon cable ( it simply pulls off and is a plug so very easy ) count ten and refit
I ( as others will tell you ! ) have extensive experience of Sargent systems !!
rich g
rich g
480
855
Worcester
A/S Warwick
since 2013
I rang Sargent and they said cover the solar panel and if the control panel works its the charge controller/regulator.I have had someone round yesterday and he can't find it,so he has disconnected a lead from the leisure battery to the panel hopefully(i will have to wait until the sun comes out to test it).So at least i will be able to go on holiday,then get it booked into get it fixed.
23,836
72,555
I await with bated breath
As a matter of interest, exactly WHAT lead was disconnected ??
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Why dont you do as suggested above? You have asked for help so why not try it? You have nothing to lose.
