More information is required. Give us a clueHi
I would sometimes like to use our outside filling pump socket-------but up to now I haven't found the isolating switch to turn it on
Nigel & Pamala
I fitted a socket to my Autotrail as I find it very useful to top up the water when pitched for longer periods when you don't want to keep backing off the pitch just to top up you're water when you don't have a tap nearby for. Hose
Mr Google tells me that the external pump device is the same for either system. However if your system works on pressure sensing then the pump will only run on pressure drop i.e. opening a tap
With the pump connected and submerged in water have you tried opening a tap?
The super fill unit is for tank filling but you don't say you have thisHi
I thought the idea of it was to fill the tank??------ I have never tried it with a tap open.
