Its still to be installed ...new van being delivered on friday to start a conversion...That’s a neat solution.
How often does it need emptying?
hoping it won't smell !!!!!....as long as there is a constant draw of air from the contained area !!. we'll soon know after using it !!! I can always do some kind of cover later if need be....As with the Simploo you're gonna need a slide/flap over the 'poo' bit as even with the fan it will still allow smells to permeate the camper I suspect.
Simploo Waterless Composting Toilets - Simploo composting toilets
great news...good to hear...In our limited experience of compost loos there is no smell if used right. We've used one in the house before, with and without a fan and as long as poo and wee are seperated and the poo is covered in a compostable material (we use cocoa husk) then there is no smell. We installed a fan with a carbon filter vented to the outside in the van to be sure, and to deal with the possibility of condensation, but no smells.
agreed...hence my (drying loo) in the title... : )There’s a lot of debate on the Narrowboat fora regarding these beasties.
It seems that most folks are not composting the solids and are binning the solid waste in normal bins. This, it seems, is causing consternation and there is challenge that these should not be referred to as ‘composting’ toilets.
Ian
It takes about a year to turn human waste into usable compost so the term 'composting' is wishful thinking. poo is about 80% water so a 'composting toilet' actually only dries out the wast.You also had ‘Composting’ in the title. What is the significance of the reference to ‘drying loo’; genuine question.
Ian
Following on from the varied and interesting contributions on this topic, well worth reading is "How to $h1t in the Woods" , 3rd Edition by Kathleen Meyer, easily available online in the UK. While I am not in any way recommending or condoning the practice, sometimes "needs must" and you also have to bear in mind that the book deals primarily with the great outdoors in the USA, where there is much more wilderness. However, the author explains about how faecal matter "composts" and the potential hazards of associated bacteria getting into water courses.Really interesting thread!
Have a poo, have a wee, add more liquid as in fresh water to flush it all away out off sight’ = loads of polluting mess to deal with.
It’s a basic function that somehow we’ve managed to morph into a nightmare of a problem (overloaded sewage plants, final effluent and overflows to rivers and beaches, near raw discharges during storm events, overload of nutrients to our watercourses etc etc).
Good to read about drying and composting in relation to Motorhomes!
The attraction of a composting loo for us is a dislike of the smell of chemical toilets and a wish to reduce the use of chemicals in the environment. When we have been on a site I just take the bottle to the loo every morning and the pee goes down the loo. Then the bottle gets a daily wash, no smell at all. The poo part should apparently last two people up to a fortnight. We have not really tested it to that extent. We are using wood shavings for coverage and a compostable liner, so the intention is to add it to our (large) compost bins when home and leave for a year or so to meld with the garden and hen coop waste. If in the wilds (unlikely, OH prefers proper toilets) I'd simply pour away the contents of the bottle in some discreet spot, it's no different to peeing in the bushes, which we have probably all done at some time. If you preferred not to test the fortnights solid waste theory, or were away for longer, since dog poo can be placed in bins when bagged, I see no reason why a small amount of human waste, securely bagged, could not be regularly binned in the same way.It's the more frequent disposal of the liquids that could create an issue????
From what I understand the "compost" would not need emptying on general holiday type trips---- but I would think it could be bagged and put in rubbish bins??
I am interested in the concept--it is becoming quite popular.
We don't have mains drainage at home so we have our own sewage treatment plant. We wanted to have a reed bed system but our soil is not suitable. I'd have considered a composting solution but for some reason my OH didn't fancy digging it out!Really interesting thread!
I understood that it's called composting because the waste needs to be composted afterwards. You do need to have a good composting system to add it to, at home.It takes about a year to turn human waste into usable compost so the term 'composting' is wishful thinking. poo is about 80% water so a 'composting toilet' actually only dries out the wast.
It did cross my mind just now that if a lot of people started doing this, you'd need the human equivalent of dog poo bins! We are intending to add our solid waste to our compost heaps at home where it will be mixed with other matter and rot down for at least a year, then go on our vegetable garden as compost.There’s a lot of debate on the Narrowboat fora regarding these beasties.
Ian
Good idea as the ones around here are too high up...................We'd need human versions of dog poo bins....
Ha HAaaaaaGood idea as the ones around here are too high up...................
besides, there's no privacy.
these remind me of the Elsan toilets from my early childhood days on a farm with a trek down to garden to the toilet, come rain or shine, wind, snow and whatever could be thrown at you weather wise. The farm we moved to also had one until the owner built a bungalow with a flushing toilet feeding into a cesspit. I recall helping my father with the overflow drain running across a field into the main ditch alongside the road. Both were marked Elsan into which you had to put their fluid. Happy days?!Just showing my composting creation...
View attachment 462416 View attachment 462417 View attachment 462418 View attachment 462419 View attachment 462420 View attachment 462421
