Cleaning interior seats with a Vax
Apache Hi Line 634
Has anyone cleaned their seats (we have a u-shaped lounge) with a Vax ?
Cloth seats and foam, wonder if anyone has any feedback from doing it themselves, as seats could do with a clean / freshen up.
Thanks in advance
Did ours no problem, test on a small out of site area first and I use a dehumidifier to aid drying. You could just prop them up so air can circulate, chhose a warm day and open windows.
Thanks - intend to remove cushions and leave outside to dry
I did mine with my vax and they were like new(few years ago) i tend to overdose the shampoo lol
If I can give you some advice, prior to any wet clean, test the solution you are using on an inconspicuous area, then thoroughly vacuum your cushions to remove any loose dirt.
if you use a Vax, clean the cushions, then use clean water in the tank to rinse out the detergent out. Detergent by it's very nature attracts dirt, so you need to get it out of the cushion or they will soil much quicker. And using something like a Vax one wet pass to 2-3 dry passes
Thanks for
Cheers for the feedback / tips
