Citroen C4 Picasso Advice, please (1 Viewer)
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
I know it's not motorhome related, but I also know there's lots of knowledge on here, so I'd like some advice, please.
I have a Citroen C4 Picasso, 2012 vintage, with the robotised gearbox. The gear selection lever above the steering column has snapped off. I can probably repair it properly once I get it on a bench, but I can't for the life of me see how to get the steering column shroud off to get access to the mounting bolts for the selector mechanism.
The plastic trim/shroud seems to be in two parts, as with other vehicles I have dealt with, but I can't see any mounting screws, bolts or clips.
Any advice would be gratefully received. :pray2:
Stephen
23,836
72,538
Dunno specifically about the C4, but some of the Citroen shrouds are clipped together and do not use screws..
I have ( somewhere ) a tool for splitting the shroud.. It is basically nothing more than a plastic wedge !
Cavs
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
All sorted, thanks. There are two bolts, largely invisible even with mirrors and lights! Found them by guesswork.
23,836
72,538
Thanks for the update Cavs.. I do wish manufacturers would stick to sensible methods and not make us guess !!
I did find my tool .. It has Fiat on the side of it so that suggests Citroen are not the only folk who have the 'pop off' cowlings..
Cavs
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
I agree. The part of the cowl farthest into the dashboard popped off as you described, so thanks for that. The bit closest to the steering wheel clearly had to have fixings and there were four possible holes; after trying flat blades and philips heads, a star drive on an extension finally reached something that felt like a bolt and bingo.
And I did fix the breakage on the bench using SupaFix APX4, which I'd never seen before yesterday. (http://supa-fix.com/products/apx4/) Squirt some powder into the joint/crack, then apply the glue and you get a filling adhesive that set like steel. Car's back on the road and without spending £219 on a new part. :eek:
