Cheyenne cruise control (3 Viewers)
Ianne
31
26
Lytham St Annes
Autotrail Cheyenne 630SE
5years
Need a little help if possible from those who are tech savvy (I'm not in the least!)
Our pre-loved Autotrail Cheyenne 630 SE (2005) came with cruise control but looking through the documentation looks like this was an add-on at purchase. It's a bit Heath Robinson especially the levers location which is right behind and touching the indicator lever.
It 'works' at 40 mph, struggles at 50 and above that is non-existent.
Anyone know of a fix, replacement option or excellent specialist in the Lancashire area who may be able to help? Long journeys are a real pain at the moment!
Ianne
Ianne
31
26
Lytham St Annes
5years
Thanks Brisey. How do I get his number? Apologies if it is obvious but we're newbies to the site.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
He advertises on the Fun forum banner at the top of the page.
Brisey.
Edit, here is his number. 01952587702
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
I second that advice, great guy, a
And funster discount too!
CheersDave
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
When you say "It 'works' at 40 mph, struggles at 50 and above that is non-existent." Exactly how does it behave? In what way does it "struggle" at 50MPH? Can you provide a clear digital photo of the stalk, it may help me to figure out your problem.
D.
Ianne
Ianne
31
26
Lytham St Annes
5years
Hi Dave. Thnx for the response. At 40, once set it will lose a few mph then maintain that speed. At 50 it maintains set speed for about 30 seconds then just decreases. Above that it will not even kick in. Photo attached that I hope is clear. Enough
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I wonder if its an old vac pump style cruise control and needa new bellows or pipe. I replaced all the pipes on my landrover cruise control with the air pipe from an aquarium and it was brilliant
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Hi Lanne, yes I recognise the stalk, it may be (and probably is) an AP300 vacuum servo system, an AP500 electric servo system or an AP800/900 fully electronic system. If you look under the bonnet is there a unit with a bowden cable disappearing through the bulkhead? If its AP300 vacuum servo it will be cylindrical, about 3" dia and 3" long with bowden cable out of one end and four core wiring at the other, often mounted to the central black plastic housing in top centre of engine bay. AP500 electric servo is often fitted near the battery and is a blocky lump with bowden cable coming out of side. Possible causes of the fault you describe are a frayed bowden cable or weak vacuum, out of the two the frayed cable is more likely. Have a look at the accelerator pedal from down in the footwell, if its AP300/500 there should be a bracket attached to the pedal with the bowden cable inner connected to it.
I will send you diagnostic instructions on Monday once you have identified which system it is. you can reply on here or by e mail to dave@davenewell.co.uk
D.
Ianne
Ianne
31
26
Lytham St Annes
5years
Hi, we are in Spain at the moment and when it finally stops raining will get out and have a look! Thanks for your continuing help, much appreciated.
