- Feb 17, 2021
- 11
- 5
- Class A
Hi , I'm new to the forum so please accept my apologies for the level of understanding that i will probably show !
I have taken over a "project " and i am really struggling getting the Chevy 7.4l engine to fire. (back story) I was told the Motorhome was driven on a short journey to undertake a re-fit. On the way the engine overheated and failed ,upon inspection the heads (one of ) had failed. It was towed back to base. A mechanic was called and he has stripped the top end,all the vacuum hoses,removed the heads and pressure tested them. One has failed as predicted. Thus i have taken on the project, which is where i have started from. Purchased a pair of matching heads which match the engine numbers. Purchased a gasket set from Realsteel plus the another gasket set as the heads had a slightly different water jet from realsteel. Replaced the heads and manifold with the correct torque and gaskets and replaced the carb. Dropped in the distributor as i thought at the correct position and tried to start her up. All i have got so far is a backfire with no sign of firing ??? I have plugged the vacuum ports excluding the distributer, intake port and rocker cover ? but i am at a loss ? Is there anyone out there who knows someone that either has a picture of the vacuum set up in idiot form or knows someone that loves to have a dabble with these 1988 mk4 Chevy bbc 454 7.4l beasts. I am in Leeds (Yorkshire) if anyone can help (I'm Happy to pay !) i would appreciate any help with this .
Sorry for the essay above, i thought it better to include most points good and bad !
