- Jan 11, 2018
- 1,235
- 1,470
- Chausson Welcome 85
- Since 2018
I have a 2008 Chausson Welcome 85.
It passed it's MOT yesterday and the garage helpfully pointed out some rot in the floor. Not an MOT issue.
The affected area lies just behind the nearside rear wheel and is probably just due to spray from the wheel penetrating the floor structure.
Inside the motorhome the area affected lies inside the bathroom, between the loo and the washbasin.
Fortunately there was a panel I could remove easily at floor level. There seems no evidence of water problems from inside.
Looking outside the area affected looks like about 9" square.
Looks like it has been there for sometime, it's not recent.
This needs fixing, of course two routes, DIY or Professionally.
The floor appears to be marine ply or similar laminate, about 1.5" thick and of course faced on the inside with the floor covering. The outside surface appears untreated.
I would appreciate any comments on whats required.
This is the plan if I do it, goes like this:-
1) Use a plunge cutting tool to cut the rot out from the underneath, part of the area extends to the straight edge of the floor
1a) Treat the xposed 'endgrain' with epoxy.
2) Use the removed section to mark out the replacement shape. In 1.5"marine ply.
3) Remove the interior floor covering and glue it onto the replacement bit.
4) Glue in place with something very strong and durable, one of the Sika adhesives.
5) Cover the area and beyond the jointline with another thin marine ply panel.
6) Seal the whole area, underneath , with epoxy.
Note, the area is not visible in the washroom.
What do you think?
The alternative is to get somebody like Cannock Resprays to do it.
(West Midlands area)
I may have to extend my area to totally remove the rot.
What do you think?
