- May 29, 2013
- 2,598
- 19,237
- Chausson best of Flash 10
- Several years now
Like a few others I got a bit sick of the Project 2000 electric bed needing to be re-programmed way too often.
So last week I started ripping out the old control system with a view to fitting a simple up - down switch system, albeit with a couple of end of travel switches.
What did I find in the existing system ? A power control relay without a flywheel diode !! Now this is not on the electronics board itself, but does supply power to the board, so maybe, just maybe the lack of the diode COULD cause enough interference to reset the board memory now and then.
As I had bought all the components to convert the system to manual I am going ahead with that, but if you have a project 2000 bed which is giving you problems as a first call I'd fit a flywheel diode to the power relay coil. The relay is situated under the big plastic cover which shields the motor and winding system, it's by itself fixed to a rail, you can't miss it. The diode could be a n4001 or something from the same series and will cost a couple of pennies from Maplin. Just make sure you fit it correct way round on the coil connections.
For more info on the flywheel diode look at the link below.
https://resources.altium.com/bill-o...-to-prevent-electrical-noise-in-your-circuits
