Yes, that is correct, I just want to know what the maximum train weight of the vehicle is I.e. the van,trailer and trailer load, theNot sure what you mean. Train weight infers a trailer is attached.
I'm not sure the train weight is relevant. So long as you dont exceed the maximum towing weight of the motorhome. Unless you are talking driving licence. C1Yes, that is correct, I just want to know what the maximum train weight of the vehicle is I.e. the van,trailer and trailer load, the
So in this example its 5850kg if the trailer is braked?
Correct, this is our V5So in this example its 5850kg if the trailer is braked?
Not always there are no trailer weights on my V5 the spaces are blank.
I don't know what Kupplungspunkt is but the max is 100kgsIt should be provided by the manufacturer as well. I need a translator for mineView attachment 497028
It's the max weight on the towball of your towbar.I don't know what Kupplungspunkt is but the max is 100kgs
Towbar weight.I don't know what Kupplungspunkt is but the max is 100kgs
You cannot legally tow anything then.Not always there are no trailer weights on my V5 the spaces are blank.View attachment 497024
16.4 & 18.4It should be provided by the manufacturer as well. I need a translator for mineView attachment 497028
According to the brochure , here;Does anyone know the train weight for a Chauson 648 it is a 2021 van
thanks in advanace
Ok you two. Who is owning up to googling it?Towbar weight.
Not unless it is the converters and the last one.Donāt you have a weight plate on the MH; itās detailed there.
Ian
No, it is a van I was looking at at a dealer so I do not have any paperwork, hence the question.Donāt you have a weight plate on the MH; itās detailed there.
Ian
Well as far as that goes it does say on my CoC 01: 2000 kg & 02 : 750 kg so I can prove it is able to tow however I think when things get back to normal a bit more I will get DVLA to put this on the V5? They were provided with it when I imported the van so obviously didnāt or couldnāt be bothered to fill it in.You cannot legally tow anything then
thanks to everyone for your replies, I think I now know the answer.
Oh yes, I intend to. The Chauson is only on tHe shortlist at the moment.If you've got time then I would still give the dealer a call to see what they advise; even if it's just to check if they do know anything about the product they sell, lol
Not necessarily, the weight could just have been omitted from the V5.You cannot legally tow anything then.
Yes worth sorting it out. As pappajohn said check the vin plate, converters one, as that should show a weight if it can.Well as far as that goes it does say on my CoC 01: 2000 kg & 02 : 750 kg so I can prove it is able to tow however I think when things get back to normal a bit more I will get DVLA to put this on the V5? They were provided with it when I imported the van so obviously didnāt or couldnāt be bothered to fill it in.
The Hymer Stuf 3 Vin is perfectly correct GVW 4500 front axle 2300 kg rear axle 2500 kg GTW 6000kgYes worth sorting it out. As pappajohn said check the vin plate, converters one, as that should show a weight if it can.
As above DVLA have just not filled in the V5Not necessarily, the weight could just have been omitted from the V5.
The only way to tell for certain is off the VIN plate whether it be the base or converters plate but the converter takes priority.
If the VIN is blank you can't tow at all
