Charging frequency (2 Viewers)
Paul and Kate
2,090
11,027
Stoke on trent
Auto sleeper Warwick
After being pointed to the charge frequency setting on my solar charger I've found its set at 25hz this can be adjusted to 50 or 100.
We have a 110ah banner wet battery and the cab battery set into the solar system.
My question is which is the best setting and why have 3 settings.
Paul and Kate
Paul and Kate
2,090
11,027
Stoke on trent
Sorry @Lenny HB to call you into this thread but could you also shed any light on this query
many thanks
53,493
150,287
The thread Jim liked to gives a lot of info. Only applies to PWM regulators. If you are spending a lot of time off grid particularly out of season really need to be using a good quality MPPT regulator.
Sep 3, 2012
7,557
26,084
Cheshire
C Class Elddis 175
8+ years
the frequency change is an option should the regulator interfere with the radio for example or tv. that's all it does .if you have no interference then leave it alone on the default setting.
Apr 27, 2016
6,876
8,002
Manchester
A class Hymer
Since the 80s
Battery charging is DC so where does the frequency come in?
Alternating current (AC) means the current alternates between positive and negative, many times per second usually.
Direct current (DC) means the current always flows in the same direction.
Constant voltage is the most common form of DC, where the voltage stays at the same level, or slowly varies, like a battery.
Pulsed DC is a form of DC where the voltage switches on and off rapidly. Typically this is used to vary things like light intensity or motor speed. If the light is rapidly switched on for 25% of the time, and off for 75% of the time, it will appear to be only 25% of the full brightness. Because the current always flows in the same direction, and never reverses, it is technically DC not AC.
