Change timing belt? (1 Viewer)
Sep 2, 2016
589
1,168
France
Burstner
I live in France and have a Burstner MH based on a Fiat Ducato. We bought it in 2015 but it is a 2014 model.
When we were at the dealers last week he mentioned that we should think about getting the timing belt changed as it is due every 5 years BUT when I spoke to the Fiat garage to arrange a service he said it is every 8 years.
What do you think??? Five or eight? Don't want to make an expensive mistake, but don't want to incur unnecessary costs either...
Oct 20, 2014
1,345
5,962
Hampshire
Adria Coral 680 SL
Since 2014
Ours is an Adria on Fiat Ducato base and is booked in for a full service. The garage asked when the cam belt was last changed, turns out it was in 2013 before we bought it so we’re going to bite the bullet costwise and get it done. Imagine it would be very expensive if it broke.
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Its definitely 5 years here but it would be worth contacting another Fiat main dealer and asking them to check your VIN number for clarification.
It may be different in France. The cost to change it here would be around £600, if you also changed the water pump - Not at the Fiat dealers!!!
Oct 20, 2014
1,345
5,962
Hampshire
Adria Coral 680 SL
Since 2014
Does the water pump need changing as well? We’ve been quoted £370 for doing the cam belt.
Jan 8, 2013
8,490
11,527
Burstner Lyseo 690G
That's a good price even for here.
The water pump is a bit of an issues as its not likely to be worn out, but you need to remove the timing belt to replace it!!
They are around £100 and is fitted behind the belt:Eeek:
tick59
1,413
1,409
Newcastle Upon Tyne
"Since 2005"
Get it done once you have it on your mind it will go. get it done if only to stop you worrying about it.
Oct 29, 2012
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
having mine done next week. £396 inc.vat.
Gellyneck
9,235
18,210
More than toes wet now!
Our cambelt, water pump and tensioners all done in a oner by a trade member on here @dave newell lvs . We went all the way down from Glasgow to get it done (well, we were touring North Wales anyway!).
IanW
4
8
Mudgee NSW Australia
Fiat Ducato 2010
Fellas
I noticed the terms "timing belt" and "cam belt" were used in this thread. The Fiat X250 multijet engine does not have either, It has a timing chain (two in fact) they are lifetime engine parts.
Other Fiat engines have a "timing drive belt" which is replaced periodically.
I think what you were confused with is the "accessory drive belt"
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Fellas
I am no techie, far from it, but I believe you are wrong.
Surely the 180 bhp lump has a chain cam but the 150 & 130 bhp versions have belts.
I would love to think they all had chains as my 150bhp engine is approaching five years old but I can already feel a large bill on the way. :cry:
Richard
Jul 5, 2013
11,728
13,706
Fellas
The Fiat 2.3 litre engine on the X250 and X290 UK models has belts. AFAIK the only one that has a chain is the 3 litre engine which used to be an option on the X250 and early X290, but is no longer available.
Jun 30, 2011
7,241
20,128
Barnard Castle, UK
Concorde Concerto
Richard
The 180bhp also has a belt as we!l I think, you are thinking about the older 3 litre fiat which had a chain but is no longer in production.
Aug 5, 2018
1,567
3,513
a
absolutely 5 years, it doesn't really have anything to do with differing engines or model years. It's five years because it's made of a material that degrades over time. All belts from all manufacturers are made of the same stuff, so yes change it and the water pump and all the idlers and tensioner with OEM QUALITY PARTS.. I cannot stress OEM QUALITY enough here either.
IanW
4
8
Fiat Ducato 2010
Sorry Fellas, I was wrong,
My Ducato 2010 X250 160hp multijet has a chain and I assumed all after 2010 would also for obvious reasons but not so:
I think??? the 100hp, 160hp and the 180hp have a "for life" chain and,
The 120 130 and 150 have a belt and as said require changing as recommended.
I am so glad I do not have a belt, I just completed a lap of the island (20,000km) and there are some places out there where a broken belt would mean a considerable problem.
I did my lap anti-clockwise of course because it is shorter (we drive on the left)
Ta
Ian
Aug 5, 2018
1,567
3,513
a
For life until it starts rattling. ?
Nothing is for life, only warranty, after that they couldn't give a ?
Jul 5, 2013
11,728
13,706
Ta
Ian
I think you will find that is because Australian models have different engines. In Europe all of the engine options of the X290 Ducato now use the 2.3 litre engine and all use belts. The only difference is the power output. The 180hp version used to use the 3 litre engine which had a chain, but that has now been replaced by a similar output 2.3 engine with a belt.
Feb 2, 2019
1,069
2,523
Pilote G740C
Richard
I'm just wondering how you got on with getting your cam belt changed and if you had it done, where did you take it?
Oct 30, 2010
4,256
20,707
Since 2008
Went to Simpson’s at Great Yarmouth where I’ve always had my servicing done as they understand motorhomes and are Fiat Professional. They can also grease the AlKo rear axle.
After their reception bod assuring me that the belt didn’t need changing ??? I booked it in anyway.
Bloody expensive but they seem to have made a decent job of it. We’ve done probably over 3k Miles since and nothing has gone bang.
Richard.
Oct 12, 2009
10,663
23,655
A Class N+B Arto 69GL
I have just had mine changed at 5 years. I was hoping to get another year out of it, but to be cautious I asked the garage to inspect it, which they did and found minor deterioration so it was changed - I saw the old belt after so I know they were not scamming me.
Geoff
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Anyone changed their belt (X250/2012/150bhp) as DIY ? is it do able ?
Think mine needs doing.....
If i could get it done for £400 here i'd just go for it but it will likely be much more, hence i need to check if DIY is even worth thinking about.
Apr 22, 2018
6,825
12,579
Herts.
Adria Coral lowline
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Went down to my friendly camper van garage that i was amazed to find had re-opened last week and he was keen to offer me a nice price.... got her booked in for 4th May for the belt only. I asked about the water pump and he said it didn't need doing with only 40k on the clock, also it was a chunk of change more if i had really wanted him to do it.
So at least we can get that task ticked off the list.
