Cesspit divining - a sort of toilet thread
Eastbourne East Sussex
Hymer low profile
Since 1972
We drove into @ukbill hacienda in Alicante province and had a nasty jar when our back wheel dropped down a hole in the ground.
The motorhome on that side was resting on the chassis and plumbing the hole with a broom handle showed it was at least 5 foot deep. I called our breakdown provider DAS via Comfort insurance and in about an hour a splendid Spanish chap with and enormous truck arrived and with the aid of my 2ton bottle jack and lots of bits of wood managed to jack it up
And then was able to tow it out with his winch plus me driving it out, great relief all round. The hole was then revealed as a cesspit which Bill didn't know about.
This produces an unexpected bonus in that he can now install a waste disposal point for any motorhomers who visit. Don't all rush at once as there is really only room for one at a time as Bills motorhome is here too. There is a bodega 5 mins walk away that does a very drinkable red and Rosado at €4.95 for 3l so no rush to leave :wine:
That was a bit of a sh*t shock, how did the van do, much damage or did you get away with it?
Don’t know how to like that post ! Looks nasty and I hope no damage done. How mad is that to tarmac over the wooden top :eek:
Good job it’s been found and can be made safe
Edit perhaps the wood from the breakdown truck ???
What was otherwise over the top ?
Nearly dropped in the **** there. :) We have a sewage tank in our driveway which was covered with 3" softwood planks when we moved in. I've replaced them with 5" thick oak ones and they can take the weight of the MH when necessary - although I try and avoid this.
The cover was actually concrete about an inch or less thick, with reinforcement wires which weren't even in it, covered by sand and grit so completely invisible. Appears to be no damage to the motorhome. Tough Mercedes chassis and Armitage tow bar.
I suppose it could have been worse
You could have fell down the hole yourself instead of the motorhome
Then you would really have been in the brexit
:eek: glad it all worked out for you and no damage apart from the new underwear
What did you expect, Grenville driving, Shirley, guiding, disaster waiting to happen, :):whistle::whistle:
Presumably you did actually stop overnight rather than just go through the motions?
Yikes, thankfully this incident didn't result in a very damaged motorhome. :eek:
All's well that ends well. (y)
Since, we have tried the white at the bodega and it is very good too, made of a couple of grape varieties I've never heard of but tastes like a sauvignon blanc. Again a mere €4.95 for 3L box or a bottle at just over a €. A 3l box is a good fit in our fridge door still giving room for the milk, not room for the white as well as the rose though. We keep the red at ambient temperature 18 to 35C :D
Glad you got away with it.
We had a similar, though less traumatic experience in our own drive.
Reversed the m/h further up than usual and got the back wheel on a cast iron inspection pit cover which cracked and partially collapsed. Luckily it was so shallow that the “bits” jammed and we managed to drive it out with the help of a tow from our car. We replaced it with a steel one the next day.
Cracked the slab covering a Guly on a campsite once with the RV . Good job I was leaving not arriving!
