Carioca 10 Step Problem
shades32uk
Carioca 10
Hi Everyone,
There seems to be a wealth of knowledge on here so it seems very likely that someone may be able to help regarding an issue with the retracting step on my vehicle.
The step just seems to have stopped working ( retracted , thankfully ) I have checked all fuses and they are all fine, the fridge is still working on battery when vehicle running, so all Ok there.
I have checked the cut off switch which I assume is a sensor of sorts for retracting the step when you start the vehicle- this is also fine.
My question is , Is there a further relay for the step power anywhere else on my vehicle as I am running out of ideas now and i am suspicious that this may be the case. Also with switch on the step removed I would have thought that the step alarm would sound, this also did not happen so fairly confident that there is a power supply problem with the motor ...
Many thanks if you can help at all, I am trying to sort this before a trip along the Rhine in two weeks
Marc
If anyone else has this problem then there is a relay behind the exterior lower fridge vent tucked up out of the way, one of the terminals had corroded sufficiently to fall off as soon as I unscrewed the mounting screw. Had to do a bit of a repair to the wiring and hey presto , all is good again !
You could do with a multi meter to check if there is power getting to the motor
Oops, didn't read your second post.
Glad your sorted and thanks for detailing the problem (y) (y)
Welcome to the forum by the way (y) (y)
Thanks for the welcome, will be scouring the forum when I get a moment before I leave in a few weeks ?
