2011 2.3 l Fiat X 250. Wait for it............ £1,450.00
Check if the waterpump is driven by the cambelt or auxiliary belt.
If it is driven by the auxiliary belt then you do not really need to change it as pump failure will not affect the cambelt and associated catastrophic affects. On my 3 Ltr x250 the waterpump is also the engine mount and is a pig to change. I suspect it might be the same on the 2.3.
Not far out. When mine went into limp mode in 2018 the main agent were on £120 ph.£100+vat as a minimum hourly rate of which the mechanic may get £15.
Even when I bought my brand new Toyota Hilux pickup in 2004 it never saw a Toyota dealers workshop for anything.
I thought that the 3 litre was a chain cam?Check if the waterpump is driven by the cambelt or auxiliary belt.
Couple of points on the various comments.
It does seem expensive, however these are main agents working to the Fiat approved schedule and using Fiat genuine parts at their listed price, they will (or at least should) carry out the work to the approved schedule i.e. do the job as per the Fiat manual, that will ensure the job is done thoroughly and correctly using the correct tools.
Perhaps a good idea if those that decry the charges familiarised themselves with exactly that that entails, they may be surprised.
The job can be carried out more quickly / cheaply by omitting some of the recommended steps and using pattern parts (yes I'm aware of the "who makes Fiat parts" argument) I'd guess most of the very low costs some continue to report will be doing exactly that.
There is every possibility that a cheapo job will work out OK but there is just as much a possibility that it won't, I've seen questions and references to vans running poorly after belt changes, which I would bet are caused by making short cuts to the procedures that Fiat recommend.
If you want to save money get the job done by a company / someone that you can trust from previous knowledge or recommendation, that will be able to charge a more reasonable hourly rate than the £100 an hour of the main agent.
The cam belt does drive the water pump as well as the high pressure fuel pump, which has to be removed to change the water pump.
Might be better if some that reply had actual knowledge of what is entailed, rather than relying on hearsay and keyboard mechanics.
Mines going in on 02.02 for a cam belt kit they quoted me £432 Inc vat and that's for a dayco kit ,, I have had a Cambelt, wheel, bearings,exhaust and service done there before , they are a commercial garage with contracts for local councils I will post when it's done
Thats seems low just the parts if they used genuine Fiat are £480.In November, I had the timing belt, tensioners and auxilary belt changed on my 2016 Fiat X290 2.3L 130hp at my local Fiat Professional dealer. They said because of the very low mileage (15,872) changing the water pump was unnecessary.
Labour: £280
Parts: £233
Sub-total: £513
VAT: £103
GRAND TOTAL: £616
Labour: £280
Parts: £233
Sub-total: £513
VAT: £103
GRAND TOTAL: £616
