Calcium build up
Alness, Cromarty Firth
Hymer B534 DL (2017)
Well travelled
Living in the Highlands we don't get calcium build up in our water system. However whilst we were travelling through europe last year we noticed thee kettle was getting deposits in it.
Our van was bought second hand and came from southern/midlands area. So my point is how do we know what the Truma boiler is like if you live or use your vans in these areas ? Does it get get fouled up with these deposits ? Do you clean it with something ?
Use citric acid about every other year seems to do the trick. We live in a hard water area but don't usually fill up the water here as we usually only tour abroad.
Citric acid every year for us. Very hard water here in the south.
By it via amazon and used about 2kgs of the stuff.
Be careful with citric acid if you have a Webasto heater. It can leave you with a very big bill for a new heater as the acid can corrode the aluminium water vessel.
That said, I have a Webasto and I use citric acid to descale it but I only leave it in for an hour and flush it out very, very thoroughly. :)
We were at Alde having our heating serviced the other day and were warned about using acid products to clean the system.
The acid can react badly with the stainless steel boiler and ruin it.
Their recommendation is to use Puriclean Which will clean the water system.
I don’t know how effective it is at shifting lime scale though.
They also warned us about filling with desalinated water in Spain and Portugal.
The salty water can damage the boiler.
Richard.
Do you just stick the vinegar/acid/whatever in your fresh water thanks and then let the heating system fill up for a while before draining it ? Is there anywhere that is easy to see if you have calcium in the hot water system ? We live in an area with the V V hard water, I'm always thinking about the house but never considered the motorhome before !
Will be watching this as my van is coming up to 3 years old soon and apart from having the engine serviced twice I have done nothing else to it, did wonder if it needs any maintenance to it.
We live down south and as the water comes through chalk it’s very hard.
I mix citric acid with warm water in buckets in my house. Then tip them into van water tank. Leave for it to do its job. Then run into boiler by using hot taps. Fire boiler up to temp then again leave to do its job. Then run the water through all taps into waste water tank. Leave there to do it’s thing. I then drain it out. And you can see the white scale it contains.
I then flush through with clean water.
Don't travel to Spain,,kettle full of lime scale in a month,,,good jib vinegars cheap to descale it.BUSBY.
I would leave it alone. The deposits actually protect the boiler from corrosion. Yes, if you live in a high hardness area and use the van a lot you might have to remove the scale from time to time. Your soft water will start to dissolve the deposit over time
Just finished de cal my Truma. Can't beleive how much calcium came out!
