- Aug 9, 2019
- 285
- 5,999
- Hobby 615 af
- 2 weeks
If citric acid is good to use how much should I use in a 100l tank?
I've always found prune juice very effective.Stroppy Bird Thanks for your help, seems to have cleared out some gunk and it feels better having done it!
If your adding food grade (cheap on amazon) citric acid to the fresh water tank, it’s worth descaling your boiler at the same time.Stroppy Bird Thanks for your help, seems to have cleared out some gunk and it feels better having done it!
Thankyou too SpeedyDux and ctc- will try cola next time
Milton. Cheap as chips and Baby Safe. Just follow simple instructions.
I put it through mine without problems and clean boiler with vinegar....without problems.I don’t think you can put Milton through your boiler.
Not applicable.dependant on the boiler type it may have a stainless steel tank liner and you may be building problems for the long term extract below from the british stainless steel association ref https://www.bssa.org.uk
Disinfection of stainless steel equipment
Chemical disinfectants are often more corrosive than cleaning agents and care must be exercised in their use.
Hypochlorites
Hypochlorites, chloramine and other disinfectants can liberate free chlorine, which can cause pitting.
Sodium hypochlorite or potassium hypochlorites are often used in commercial sterilising agents. If these substances are used with stainless steel, the duration of the treatment should be kept to minimum and followed by thorough rinsing with water.
At higher temperatures, chloride-containing sterilising agents should not be used with stainless steel.
Milton solutions (hypochlorite & chloride) can be very aggressive to stainless steels.
I fail to understand how my reply of 'not applicable, is seen as confrontational. However as the old saying goes there's nowt so queer as folk and on that little quotation will leave you to it, me old fruit pastel. Have a good weekend.any reason its not applicable PhilandMena? out of interest rather than being confrontational
Your bang on and do I feel like a right wally right now. Not the first time either. LOL Anyway, my boiler is a Webesto and it's guts are Aluminium. The operating manual says to descale every year or two with white vinigar. I empty the water and boiler pour in about 5 litres of vinigar then about 10 lts of cold water turn the pump on and fill the boiler. I then switch on the boiler heater and leave for about 3 hours then drain the boiler direct and flush the water tank and boiler through with a shed load of water and it's job done.possibly because you failed to read my intent, it was I that was trying to not be confrontational, and asking YOU to expand a bit on the NA statement with fact. happy roaming
