I open the window. Apparently less fuel consumption than AC and can't get fresher especially travelling in Narfook.For those who have it, how often do you use it?
We have ours on, when driving, all the time.
I know it lowers fuel consumption, but for me it seems to make the cab less stuffy when its on.
Checking what ???will be going out and checking under the bonnet in the morning
Never heard that. Is there any confirmation about this or is it just??????Can be expensive if you don't use it, seals dry out and you can end up with a few grand repair bill.
Apparently there is a dip stick. The one who's opening the bonnet and checking gas.You can't see the gas and there's no dip stick
General opinion of aircon engineers is to use the air con for minium of 10 minutes on every journey to keep the oil circulating which keeps the seals lubricated. If you don't use the aircon the seals dry out joints start leaking and the compressor can fail often happens on cars where the owner doesn't use the aircon over the winter. If you get a decent aircon engineer to service your aircon he will drain it refill with a measured quantity of fresh oil before re-pressurising the system.Never heard that. Is there any confirmation about this or is it just??????
Would have been really nice but when we got to France in July we realised ours didn't work
Now we are home we will get it looked after local firm £49 if under 600g of gas £72 if over will be going out and checking under the bonnet in the morning
I made a mistake a few years ago of having a non working air con in a car regassed. Big mistake as it only worked for a short period before all the gas had gone again. Turned out to be a leak in the compressor. To test for leaks I think they pump a dye through the system with nitrogen, the dye will show where the leak is.Would have been really nice but when we got to France in July we realised ours didn't work
This is what I have been led to believe as well.In the Motorhome and the car always permanently on.
General opinion so not fact then?General opinion of aircon engineers is to use the air con for minium of 10 minutes on every
My ex boss used an ultra violet dye and special torch.To test for leaks I think they pump a dye through the system with nitrogen, the dye will show where the leak is.
Needs 'exercising' for 20 minutes every month or so to redistribute the lubricant and refrigerant.General opinion so not fact then?
So what happens if your journey is only 5 minutes?
I do appreciate what you are saying but 10 minutes on every journey?
It is suggested, with night heaters in wagons to run it for a few hours once a month in the summer so as to keep it working throughout the winter but tbf, AC for 10 minutes every journey?
Tbf, when I got my new car (6 months old), I did query with the Mercedes dealership about the max demist mode and the AC came on at the same time and he said, that's correct in Mercedes, sir!I use mine in the car almost daily. Air conditioning is a system or process of controlling the temperature AND humidity of a given parcel of air. So when you are misted up, use it. You can have the a/c on and adjust the temperature to suit. It doesn't just blow cold. And if you don't use it, you will lose it. Then you will have to pay dearly.
Craig
Now, 20 minutes a month is a LOT different than 10 minutes every journey. I'd do 40/50 minutes every day and that would probably equate to 60 times more than 20 minutes a month.Needs 'exercising' for 20 minutes every month or so to redistribute the lubricant and refrigerant.
It is advised to exercise for small time at regular intervals. It isn't required to have in use all the time .Never heard that. Is there any confirmation about this or is it just??????
They used to use Freon in those days banned now. The modern gases the particals or whatever you call them are much smaller and can permeate through rubber hoses in the system so you always loose a small amount of pressure hence modern systems need topping up.My 1978 Volvo never lost any gas. Perhaps they used different seals then? More recent vehicles have lost gas as they got older and re-gassing became an annual procedure. Told to switch air/con on at least once a month, but how can you remember and what if you don't use it over winter? Latest one is left in "auto" mode, so it decides for itself whether to use air/con or not.
