Burstner 2017 control panel warped (2 Viewers)
Dean Steele
Hello i have a new Burstner 747 Argos and the main control panel for lighting etc has warped our dealer said to take it back for repairs but they are over 200 miles away 400 mile round trip . Has anyone else had same problem or know what is wrong please .incidentally I ordered factory fitted solar panels so i do not plug it in to keep leisure batteries charged / not sure if I should plug it in when not in use . Only used it twice since it arrived in June
Dean Steele
Dean Steele
I am not sure how to remove the damaged panel but will try to thanks
17,635
43,369
not much point trying to remove it as i suspect the damage was caused by the cut out in the wooden cabinet is slightly too small, just fitting another would result in the same failure. plus burstner could say you caused the damage trying to remove the panel
bigtwin
5,245
9,951
Derby
Concorde
Difficult to see clearly but is it the front panel that is warped or is it that the circuit board behind the panel is not secured/aligned properly?
Ian
Oct 26, 2016
162
54
kent
Burstner Elegance 810G
since 2003
I'd make a weekend of it and travel to get it done properly,I have the same problem I live in kent but purchased my burstner from camper uk 190miles each way.
