sallylillian
I have this in my van and I suspect it was me who blasted too hard with water as the fans stopped working. So I went to the local (here in Silves) PC shop and bought what were in terms of structure the same fans. BUT they have red and black leads plus a yellow and the originals did not have 3 wires. I connected the red and black as + and - respectively and the fans work. However switching to manual on the control panel does not cause the fans to go to high speed. There is a green wire in the cable from the controller that goes to what looks like a diode but I assume is a temp sensor and this connects to the reds. So I wonder if I need to connect the yellow somewhere, assuming it is some sort of signal wire?
Any clues?
Any clues?
